Can Drywall Suck In Moisture? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-04-2012, 05:52 PM   #1
Can drywall suck in moisture?
i just dumped 4 -6 five gallon buckets full water on my basemet floor to clean it. with in 10 minutes it was all evaporated before I could even start to mop. Where did it evaporate to? The drywall? Am I screwed.
aigsrone is offline   Reply With Quote
Old 08-04-2012, 06:04 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 230
Does the drywall touch the bare floor?
Old 08-04-2012, 06:12 PM   #3
kwikfishron's Avatar
Rewards Points: 184
Down the floor drain.
kwikfishron is online now   Reply With Quote
The Following 2 Users Say Thank You to kwikfishron For This Useful Post:
DangerMouse (08-04-2012), gregzoll (08-04-2012)
Old 08-04-2012, 06:46 PM   #4
Rewards Points: 13,296
It's not going to suck up that much that fast.
If this is a finished basement you just may have water now under the bottom plates, the baseboard and the drywall if it was installed to close to the floor.
Old 08-05-2012, 08:19 AM   #5
Rewards Points: 940
Is the pope catholic?
cleveman is offline   Reply With Quote
Old 08-05-2012, 09:47 PM   #6
i don't have floor drain. drywall does not touch the floor.
those buckets were spilled across the basement. the air was humid for 1-2 days afterwards. but where did all the water go?
Old 08-06-2012, 06:53 AM   #7
chrisn's Avatar
Rewards Points: 230
http://en.wikipedia.org/wiki/Evaporation
Old 08-06-2012, 08:41 AM   #8
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Concrete also absorbs moisture (basement floor): http://www.floorexpert.com/armstrong...2?OpenDocument
Get a dehumidifier and pull the moisture out of the area.
- Build Well -
In wall gutter downspout causing mold on drywall. chrispy35 General DIY Discussions 12 05-06-2011 11:35 PM
Cutout in drywall around sink coutertop bananey Drywall & Plaster 4 05-04-2011 05:47 PM
Cleaning brush StevenH Painting 19 02-06-2011 12:13 AM
Basement Moisture, what's this? bergerdude Building & Construction 1 06-11-2010 02:27 PM
Large drywall patches - best way to fix? Screw them to what? Scott99999 Drywall & Plaster 6 11-19-2009 05:34 PM
