Old 08-13-2014, 10:06 PM   #1
Share |
Question
Can drywall be exposed to the elements?
The house is raised on pilings, and the underside of the floor joists are covered with two layers of drywall. Insulation is between the joists and drywall. The question is, can drywall be used outdoors? The house will NOT be "closed" in around the pilings....It will be left as-is as seen in the pictures.
djchase88 is offline   Reply With Quote
Old 08-13-2014, 11:49 PM   #2
Tileguy
Bud Cline's Avatar
If it is (in fact) everyday garden variety drywall then...good luck!!!
Is this New Jersey?
The Following 2 Users Say Thank You to Bud Cline For This Useful Post:
djchase88 (08-14-2014), gregzoll (08-15-2014)
Old 08-14-2014, 07:13 AM   #3
I would have at least used a product like Densshield, paperless, or any number of moisture resistant drywall.
Then primer and paint with a mildicide in it.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
Old 08-14-2014, 07:43 AM   #4
Good question. You should check with your local building codes.
It's kind of hard to tell from the pictures, but it looks like it won't be exposed to direct rain. If so that would obviously be a no. But is this basically the same situation as a garage? I'm not really sure. A garage would have the same temperature and humidity factors as this space, I guess. It might work.
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
Old 08-14-2014, 08:49 AM   #5
Is this New Jersey?
Yes this is new jersey. It is a house on the jersey shore. I am unsure what type of drywall it is, but it doesn't look any different than regular drywall. I do know there are two layers of it.
I am also unsure about the spackle that was used. I don't know much, but I do know that when you wet it, it does loosen and get soft (like with a wet sponge).
Old 08-14-2014, 10:33 AM   #6
When installing drywall, it's called joint compound, not spackle. I would hope in an exterior application like that, they would have used setting compound. From your description, it sounds like they used regular drying compound, which would not have been my choice.
Old 08-14-2014, 10:48 AM   #7
PoleCat's Avatar
I would think that the elements would eventually get to it by temperature swing and humidity.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is online now   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
Old 08-14-2014, 10:49 AM   #8
Yeah I know polecat, but doesn't that make you wonder about all the garages finished in drywall?
Old 08-14-2014, 03:10 PM   #9
Tileguy
Bud Cline's Avatar
I beg to differ! I don't think this is at all like a garage. A garage isn't normally subject to mist and fog and sea-air-drift and blowing rain and morning dew and saltwater spray.
I would say at the very least the entire area should be painted with a high quality epoxy paint/coating and all transitions and connections to dissimilar materials should be heavily caulked.
There are professional painters here (at DIY Chat) that could help with those recommendations.
The Following User Says Thank You to Bud Cline For This Useful Post:
Old 08-14-2014, 04:00 PM   #10
It's done every day here in Fla. in swimming pool enclosures and lanais, fancy name for screened in rooms. Some are left smooth most are knockdown texture. Then just primed and painted. Sometimes there is a problem after a few years and that is just is the tape comes loose. That usually comes back to a poor taping job. This includes homes right on the water.
The Following User Says Thank You to ToolSeeker For This Useful Post:
Old 08-14-2014, 05:11 PM   #11
I was replying to polecat, and the attributes he mentioned specifically humidity and temperature changes. And with regard to those, he said they would "get to it". In that context, I said basically then how could garages handle those things?
Blowing rain or sea spray is not likely to get on that drywall. However it is more likely to have fog or dew. It's less exterior than siding, and more exterior than a garage.
Old 08-14-2014, 05:17 PM   #12
PoleCat's Avatar
Where I live it is very common in spring and fall for extreme cold temperatures to be quickly followed by warm wet air masses. All cold surfaces become wet with condensation. Metal more so. Drywalled garages that are not painted shed their tape.
Old 08-14-2014, 05:22 PM   #13
Tileguy
Bud Cline's Avatar
Tell that to the next "Sandy" that comes along.
Old 08-14-2014, 07:31 PM   #14
Right, that's why I said it makes you wonder about that. There are a lot of unpainted garages. The one in this post will be painted, certainly. So it will be interesting to see how it holds up.
Old 08-14-2014, 07:38 PM   #15
Can you put exterior paint on drywall? That should keep it sealed I would think.
cjm94 is offline   Reply With Quote
The Following User Says Thank You to cjm94 For This Useful Post:
Reparing/Finishing drywall under skylight..help!! greymoose Drywall & Plaster 4 11-25-2013 10:34 AM
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 04:37 PM
Is tape necessary to repair holes in drywall (in garage)? Scotch99 Drywall & Plaster 4 08-22-2011 01:08 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
