Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 06-06-2011, 11:28 PM   #1
MikeKy55's Avatar
Butt joints (again)
How good is good enough? As some will remember, I'm finishing my basement. I'm finishing the drywall now. I have built hot rods all my adult life and I tend to try to get the walls straight enough to paint gloss black. Needless to say it works me to death. The recessed joints aren't a problem. But the butt joints are killing me. I'm currently mudding out 18 inches or so either side of the butt joints. I sand them and feather them out, but when I feel them I can still detect the raised area. I used mesh tape and I sanded the first coat till I could just begin to see the mesh in an effort to keep the center as low as possible. Then on the second coat I skimmed over it very lightly. Assuming I'm actually sanding the compound flat from the center out in both directions, how wide should the feather be to keep the rise in the surface from being noticeable? Thanks
MikeKy55 is offline   Reply With Quote
Old 06-07-2011, 07:21 AM   #2
I make love to my walls
Butt joints (again)
My butts are 36 inches wide. I use a flat 18" trowel on both sides after my tape is semi dry then on second coat I run a curved 16" trowel through the middle, then skim it on the third. Once I. A while after I sand, if it's a bad one I'll double up with a curved trowel on either side again. Not much sanding in between coats- you dont want to take off what your trying to build out
Arey85 is offline   Reply With Quote
Old 06-07-2011, 09:43 AM   #3
Old School
Willie T's Avatar
Butt joints (again)
Lord have mercy!
Aren't we EVER going to finally learn about 'butt boards'?
Willie T
Old 06-07-2011, 10:15 AM   #4
MikeKy55's Avatar
Butt joints (again)
Some of us are a little slower
Originally Posted by Willie T View Post
Lord have mercy!
Installing beadboard on wall over 8ft tall - butt joints? Wildroze Remodeling 3 09-01-2010 01:00 PM
hiding butt joints - need help kupalino Drywall & Plaster 8 05-27-2010 07:38 PM
Drywall butt joints question kupalino Drywall & Plaster 6 04-08-2010 01:46 PM
Taping uneven butt joints! Lindsay8 Building & Construction 2 06-17-2009 01:08 PM
caulking butt joints on siding downunder Building & Construction 7 11-13-2008 04:56 AM
