Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 12-09-2012, 07:06 PM   #1
Bullnose with paper flanges
I am replacing square corners with bullnose and have the old corners pulled off. I think I need to scrape off more of the old coating to attach the paper to drywall, my husband says attach it to the existing wall. Which is the best way?
MaryBeth9 is offline   Reply With Quote
Old 12-09-2012, 07:32 PM   #2
Super Moderator
When drywall is installed for radiused corner bead--the drywall is set back from the corner 1/2" to allow the radiused bead to clear the drywall---so you will need to cut the drywall back so the corner is open---1/2" back from the face of the adjoining sheet(even with the face of the stud)
This could be done with a knife---or a Multi tool---
ToolSeeker (12-10-2012)
Skylight Install: How to Retrofit New Asphalt Paper? amakarevic Roofing 11 06-06-2012 03:01 PM
Repairing stucco felt paper titan7 Building & Construction 5 02-26-2011 09:44 PM
Felt Paper and the Sun. Valley problems hartkem Roofing 1 07-22-2009 04:57 PM
contact paper removal scatterbrain Remodeling 2 07-06-2008 08:57 AM
