Bullnose Drywall Corners - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-20-2012, 08:35 AM   #1
bullnose drywall corners
I would like to convert my 90 degree drywall corners to bullnose. Can I install bullnose cornerbead directly over 90 degree drywall corner edges?
margiegal is offline   Reply With Quote
Old 02-20-2012, 01:17 PM   #2
Remodeling Contractor
no, take a hammer to corner and break away the compound. Then remove the metal corner. Now you can install the round one.
The Following User Says Thank You to Bob Mariani For This Useful Post:
margiegal (02-20-2012)
Old 02-20-2012, 07:55 PM   #3
Rewards Points: 36
Two draw backs to the rounded corners (although I have them in my home and like the look). It looks odd to change a wall colour on the corner. Also it's impossible to get a good back scratching when your wife isn't around.
daveb1 is online now   Reply With Quote
The Following 3 Users Say Thank You to daveb1 For This Useful Post:
Jay 78 (02-20-2012), mae-ling (02-20-2012), woodworkbykirk (02-20-2012)
Old 02-20-2012, 09:56 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,200
daves right, you'll have to settle for the edge of a door..however the door will move as you sway back and forth for the scratching
hes also right about the paint transition. you have to have an extremely steady hand to cut a straight line with a paint brush for it to look right... interior designers are notorious for specing. accent walls on homes with this type of corner bead. its also a little tricker to get the correct measurements for baseboard and crown installs
woodworkbykirk is offline   Reply With Quote
Old 02-20-2012, 09:59 PM   #5
Rewards Points: 13,694
I try to set the base and crown first then finish out the corner bead, that way I do not end up with a hole I have to fill to cover it up.
Old 02-20-2012, 11:09 PM   #6
Bullnose corners in drywall
I was asking questions today at my local hardware store and the drywall guy there said I could use sheet metal screws to anchor the new bullnose corner edging overtop the existing metal 90 degree corner bead, then mud over to finish it off. He thinks it would save a lot of mess and time doing it this way. Does anyone have any experience doing it like this, or will this method not work?
Old 02-20-2012, 11:18 PM   #7
Rewards Points: 2,212
It wont work. a round corner needs matrial 'missing' behind it to make the round. where as your existing corner is square, so no material missing.
Did that make any sense?
mae-ling is offline   Reply With Quote
Old 02-20-2012, 11:25 PM   #8
Kinda, I guess, it just seemed when he was explaining it I could see how his technique would work, but I haven't actually attempted it yet. He was not a drywall expert, just a handy employee.
Old 02-20-2012, 11:29 PM   #9
You would end up with two humps on the walls.
Not likly there's a real "drywall guy" working in a hardware store. More likly it's a guy that just happened to be working in the drywall area.
No real drywall guy would ever suggest doing that.
Your only talking about 15 min. work to do it right.
Jay 78 (02-21-2012)
Old 02-21-2012, 12:00 AM   #10
Rewards Points: 636
here are a few tips or tools on trimming around bullnose corners
http://www.rockler.com/product.cfm?p...FQxX7Aod-hCnRA
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 02-21-2012, 06:58 AM   #11
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by Bob Mariani View Post
no, take a hammer to corner and break away the compound......
I read the first part of this post, and it made me laugh....thinking that this was the suggested method to bullnosing a drywall corner.
- Build Well -
Old 02-21-2012, 06:59 PM   #12
Drywall contractor
Rewards Points: 1,070
Mae-ling is correct. For proper bullnose installation the pieces of drywall underneath should not overlap.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Wall tiling with with rounded drywall corners pmarkham72 Flooring 0 07-18-2010 08:06 PM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 09:42 PM
Corners with drywall? Ol' Luke Building & Construction 9 11-09-2006 06:17 AM
Drywall question Not Sure Building & Construction 6 08-27-2006 03:05 PM
