-   -   Bullnose Corner bead question (http://www.diychatroom.com/f101/bullnose-corner-bead-question-97487/)
ryan5068 03-06-2011 10:55 PM
1 Attachment(s)
Hey guys a quick question I have created a bulkhead all the way around my basement ceiling and I am going to use the rounded corner bead on the bulkhead. However in the corner of the bulkhead I made a 45 degree angles instead a traditional 90 degree corner. Is there a 45 degree plastic transition piece. I would essentially need two for each corner. Hopefully this will help especially if you have google sketch up
ryan5068 03-06-2011 11:01 PM
1 Attachment(s)
Here is a picture of the bulkhead corner in question. It is a true 45 degree angle. Thanks in advance.
Willie T 03-06-2011 11:06 PM
You can run one edge long, and (carefully and slowly cutting) use a miter saw to cut an abutting piece at 22.5 degrees. Slide it into the side of the previously installed long edge like a cope cut.
ryan5068 03-06-2011 11:19 PM
okay I could probably handle that but do they make a 45 degree piece like they do with the 90 degree angle?
Axecutioner-B 03-07-2011 12:17 AM
They probably do but I have never seen one. Willie is right, just take your time with your cuts & you will be fine. For both plastic & metal bullnose i use tin snips to make my cuts, they are rarely perfect .. BUT .. they are always close enough that a good drywall finisher will make them look beautiful (even me) :thumbup:
ryan5068 03-07-2011 12:32 AM
Okay thanks I will do it that way. Now another question how do you attach the vinyl bead. Do you use staples a specific staple to attach them to the sheetrock. Do they make a stainless steel staple so they wont rust. I have seen the just plain metal staples rust. Thanks
Axecutioner-B 03-07-2011 11:36 AM
Metal staples shouldn't rust under the drywall mud. For vinyl bead we staple them with a pnuematic stapler with 1" or 1 1/4" staples. You can use a spray adhesive but for long straight runs like you have i don't think that would be necessary. The spray adhesive does work good tho & with your concern about rusty staples maybe spray adhesive would be the good alternative. If i were doing the work in your picture i would be using metal bullnose with staples, but thats just me.
oldrivers 03-07-2011 10:12 PM
2 Attachment(s)
yes they make that transitional piece , are you using the wide bullknose or the thin one ? i prefer the wide one ... go to a drywall supply house and they can get you set up.
oldrivers 03-07-2011 10:21 PM
one more
1 Attachment(s)
hers a wide bullnose i did with a glass block wall.
JoeLena 03-08-2011 08:18 AM
Is it like this one? Look at the bottom of the page here and see if it looks right. I haven't used one like it yet, but have a similar need soon. http://trim-tex.com/products/34bullnose.php
MnDrywallRanger 03-13-2011 04:26 PM
Yes there are fittings for both vinyl and metal bullnose. Make sure you match the right size to the bead you buy. Basic bullnose comes in 5/8" round for a slighly tighter roundness or a 3/4" for a slightly wider roundness.
Tip...when sheetrocking make sure you hold the sheetrock flush to the wood on both sides of the corner or the bead won't properly fit.
I personally use vinyl bullnose because it's easier to use a miter saw and cut the inside corners instead of aligning fittings. Outside corners you have to use the fittings.
Note...when inside corners are mitered a small bead of caulk around the joint just before texturing (or painting) works nice.
To cut with a miter saw I made a block of wood to place the bead on to help.
To apply the vinyl bead I simply use a duo-fast hand stapler to put them on and then mesh tape along the entire edge to prevent cracking.
SuperHans 03-13-2011 08:43 PM
Nice work. How did you go about applying that brick pattern? Is it just etched into a skim coat?
