Bulkhead Removed - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-02-2014, 08:27 AM   #1
bulkhead removed
hey guys..
redoing my kitchen and started by removing the bulkhead... im going to remove the cabnets this weekend and drywall the.. the new cabinets will the right to the ceiling with crown molding ... only place u will see it will over the sink and stove... i just want to make sure its seamless... any tips? ill post pictures ....
Click4chips is offline   Reply With Quote
Old 05-02-2014, 08:29 AM   #2
so over the window will be a key area
Old 05-02-2014, 09:36 AM   #3
Rob
Robpo's Avatar
Rewards Points: 826
I am equating bulkhead with soffit. Is seamless cabinets or crown molding. I would run sheetrock above window and run crown on cabinets and above window. If you are good with crown build chase around duct above range hood and crown around it.
Save cabinets for work shop.
Robpo is offline   Reply With Quote
Old 05-02-2014, 09:41 AM   #4
I'm not install the new kitchen ... And where the vert
Is... The new one goes right
Up to the ceiling and the back splash will probably run all the way up there as well ...so that one won't be as visible
Old 05-02-2014, 11:54 AM   #5
Rob
Robpo's Avatar
Rewards Points: 826
Just giving ideas. Code is usually not more than 3' above range for range hood.
Old 05-02-2014, 02:26 PM   #6
DIY staff
Rewards Points: 7,174
You need to cut the ceiling drywall about 24" or more away from the wall--
this will remove the thickened drywall corner where the soffits use to end--
If you do not do that,you will end up with a thick,uneven joint where your new cabinet crown will meet---
Old 05-02-2014, 02:55 PM   #7
Up here bulkheads are what you call soffits...boxes to hide ductwork
Soffits and fascia are outdoors next to the eavstroughs
creeper is offline   Reply With Quote
The Following User Says Thank You to creeper For This Useful Post:
joecaption (05-02-2014)
Old 05-03-2014, 06:59 AM   #8
Ok thanks for the tips guy ... Any recommendations on type of mud and tape ....?
Old 05-03-2014, 07:47 AM   #9
Rewards Points: 5,988
All purpose in the bright green lid and anything except mesh.
Old 05-03-2014, 09:46 AM   #10
Any reason for avoiding
Mesh ?
Old 05-03-2014, 02:14 PM   #11
Rewards Points: 6,652
Need a better picture of the Soffit.
Old 05-03-2014, 03:56 PM   #12
Rob
Robpo's Avatar
Rewards Points: 826
Mesh ?
Not as strong as tape
The Following User Says Thank You to Robpo For This Useful Post:
oh'mike (05-03-2014)
Removed light fixture and now lights in my house don't work! BrandyHarvey Electrical 3 07-26-2013 10:09 AM
Door trim removed, how to repaint chunders Painting 5 07-23-2013 11:03 AM
Removed linoleum on slab foundation to install ceramic tile... Question? Ler0y Jenkins Flooring 3 03-20-2013 08:57 PM
Must old thinset be removed when replacing ceramic tile? Doofusboy Tiling, ceramics, marble 2 01-04-2013 09:52 AM
