Bubbling Durabond? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-10-2010, 11:29 PM   #1
Bubbling Durabond?
Some I've never had any problems with Durabond before but I'm working on an old house and its causing me problems. The house had multiple layers of wallpaper that I removed and under that was some kind of bluegreenish paint which I assume to be lead. The wallpaper removal chipped large areas of the lead paint but I used a scrapper to remove any loose paint.
As I apply Durabond, everything looks great and its smooth. However, an house after it starts to bubble. I let it harden all the way and pryed off the bubbles. The adhesion between durabond and lead paint was excellent as it pulled the paint off in the bubbles. However, it seems to be making the lead paint bubble as it cures? Any ideas why? Do I need to remove the lead paint before plastering? I was planning to skim over the walls with Durabond but it seems to be making these air bubbles everywhere as it cures.
jonathan03 is offline   Reply With Quote
Old 06-11-2010, 03:50 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 474
You probably did not get all the paste removed.
Prime with Gardz before skimming or totally remove ALL paste.
chrisn is online now   Reply With Quote
Old 06-11-2010, 02:05 PM   #3
Drywall contractor
Rewards Points: 1,070
Durabond has a tendency to bubble, especially when applied over a painted surface (gloss paint just makes it worse). Just lightly sand after it dries and pull a "tight" skim with ready mix to foll the voids. May need two coats.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Paint blistering and/or bubbling issues stro77 Painting 8 10-05-2012 11:59 PM
Bubbling paint on ceiling caused by damp bathroom floor garv19 General DIY Discussions 4 04-10-2010 07:38 AM
Bubbling toilet last night syogod Plumbing 5 03-26-2010 09:12 PM
bubbling paint...please help! theise Painting 2 03-24-2009 06:53 AM
Bubbling Paint - Re-do Roddy Piper Painting 6 08-26-2007 01:26 PM
