Bubble's In Drywall Tape - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-27-2010, 10:47 AM   #1
bubble's in drywall tape
We are finishing our basement. My husband has began taping and it has air bubbles in the tape. Is there a way we can fix this w/o removing this tape and starting over?
rn0110 is offline   Reply With Quote
Old 11-27-2010, 10:51 AM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
If you apply an abundant amount of joint compound, then apply the tape and squeeze it down tight into the joint compound with a six inch knife you won't have any bubbles unless the walls are really wavy. Once bubbles show up you must remove the tape and start over.
XXX
Old 11-27-2010, 11:02 AM   #3
40+yrs Paint Trades
Just cut the bubbles out with a utility knife and apply a patch of tape over the blank. OR you may be able to slice the bubble at the bottom or top and insert mud with the edge of your knife.
When taping be generous with the bed coat.
hoz49 is offline   Reply With Quote
Paint problems....or just problems with the painter... deanswife Painting 5 07-30-2010 08:36 AM
Fiberglass drywall tape on ceiling lgallo Drywall & Plaster 1 03-21-2010 10:05 AM
Tape drywall joints before painting? mcraenz Drywall & Plaster 7 11-19-2009 06:28 PM
Repairing drywall tape bcouch Drywall & Plaster 2 09-08-2009 03:19 PM
any problem with priming drywall before tape and mud goes on? nonDIYer Drywall & Plaster 2 12-21-2008 10:17 PM
