Bubbles In Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-27-2009, 12:46 PM   #1
bubbles in drywall
my house had some water damage, the sheetrock had to be cut about 2 feet from the floor up, after the sheetrock was rehung, mudded, sanded, it was textured, the texture was feathered about another 2 feet up to blend with the old wall, after it was textured and painted, the area where the texture blended into the wall bubbled along what appears to be the seam.
what caused this and how can it be fixed??
the contractors have repaired the areas 3 times now.
ambiej10 is offline   Reply With Quote
Old 10-27-2009, 04:18 PM   #2
Rewards Points: 5,336
At the seam it sounds like the tape has lifted due to dry spots under it. The tape would need to be removed and retaped correctly.
I doubt the contractor who repaired it 3 times before will be able to do it. But who knows. Forth time might be the charm.
Ron
Old 10-27-2009, 04:23 PM   #3
Drywall contractor
Rewards Points: 1,070
Yep, tape did not have enough mud under it. Proper fix is to remove and re-tape.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is online now   Reply With Quote
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 10:42 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
