Bubble In Tape - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-22-2013, 10:12 AM   #16
Rewards Points: 240
this is what i have. i thin the buckets as i use it, about 4" deep.
Fix'n it is offline   Reply With Quote
Old 09-22-2013, 10:19 AM   #17
Rewards Points: 4,796
OK so that is Durabond, not Easy Sand. That is heavy duty. I would never have used that, but it can work. I would have used All Purpose for everything. That is, after all, the point of All Purpose.
If you don't like the idea of All Purpose being suboptimal and are willing to shop, then you should go with these products instead. These are non-setting compounds formulated specifically for setting (strength) and then topping (smooth application, sanding).
http://www.usg.com/sheetrock-taping-joint-compound.html
http://www.usg.com/sheetrock-topping...-compound.html
jeffnc is offline   Reply With Quote
Old 09-22-2013, 10:35 AM   #18
Rewards Points: 240
those are what i was told to use, last year. i have enough of each, so i am going to use em up.
the durabond is not hard to sand. but it sure isn't as easy as thinned ultralight.
but, next time i have a "high spot". i am going to skip the durabond and just use all purpose
Old 09-22-2013, 11:25 AM   #19
Yeah, I was really writing that for other forum readers to read, not so you'd change products midstream :-)
Old 09-22-2013, 11:33 AM   #20
DIY staff
Rewards Points: 7,174
Many pros use multipurpose for all coats---and the same for powdered bag mix---however the skill of a pro means that little sanding is required--
If your not an expert---you will be pleased that you chose light weight topping for your final coat----
Old 09-22-2013, 11:50 AM   #21
Rewards Points: 240
i have already used 3/4 of that bucket. i wasn't "pleased".
i was THRILLED
The Following User Says Thank You to Fix'n it For This Useful Post:
oh'mike (09-22-2013)
How long can I leave blue painters tape on? mae-ling Painting 16 03-06-2012 03:42 PM
Those *#@& air bubbles under drywall tape spaceman spif Drywall & Plaster 12 03-02-2012 05:22 PM
Need advice on roof heat tape. marchboom Electrical 52 12-04-2011 03:45 PM
Masking Tape Adhesive Remover? Twister Painting 13 10-01-2011 01:42 PM
First time taping - Tape has air under it theedudenator Drywall & Plaster 16 04-21-2010 11:13 PM
