-   -   Brown spots on ceiling after skim coating (http://www.diychatroom.com/f101/brown-spots-ceiling-after-skim-coating-178474/)
aminus21 04-30-2013 06:30 PM
Hello all,
I am redoing a home I just bought, the walls are plaster. I just skim coated the entire house with 20 minute and then compound. The day after I finished, these brown spots started to appear on the ceilings of the bedrooms (but not the kitchen ceiling or any walls). There were only a few spots in the morning, but after 8 hours, the ceiling looks like this..
http://s22.postimg.org/5ssvhy18t/IMG950472.jpg
http://s22.postimg.org/88uovsjbh/IMG950473.jpg
http://s22.postimg.org/uakz5u3t9/IMG_0474.jpg
I have not primed yet, and was thinking to stainblock with some Killz oil based.. and then prime with Killz water based.
Has anyone seen this before? What's the cause of it? Thanks in advance. I am hoping to paint later this week, but this just totally threw me off!
chrisn 05-01-2013 03:06 AM
If you need to use Kilz, you only need the oil based, no need at all to prime twice. As to what it is, I would say nicotine, but really hard to say from here.
aminus21 05-01-2013 09:48 PM
Today (3rd day after skim coating), some of the compound on the ceiling started to bubble and peel...
Seattle2k 05-02-2013 12:30 AM
Did you skimcoat the walls too? If so, do they also show the spotting? It makes me think cigarette tar or rust. But, then the bubbling and peeling throws me off. What's the attic space look like? Is it humid?
ToolSeeker 05-02-2013 06:43 AM
Sounds like it almost has to be a moisture problem. 3 day old mud should be hard the only thing that would make it soft enough to bubble or peel is moisture.
aminus21 05-05-2013 11:45 AM
Yes, we did skim coat the walls too, but they did not spot or peel..
aminus21 05-31-2013 08:09 PM
We added a coat of BIN. After it dried, we added a very light coat of compound and then lightly sanded. Then prime and paint. Came out great.
I talked to some painters and they said sometimes when there is stained oil based paint, they will spray a first coat of BIN, then skim with compound, then prime and paint.
Thought I'd share the update in case anyone else runs into it.
Thanks everyone for the great input.
jlethert 03-13-2014 11:34 AM
I have some areas that look exactly like this. I have re-textured whole house which has had varying surfaces, some new, primed, some original surface semi-gloss painted. The areas that this occured, had been old semi-gloss paint that was skim coated first and then when light trowel texture was applied the 2nd day, the following am it looked like this. I did not see anything coming through 1st coat/skim coat. Is it possible the skim coat was not dry? Some of it was exterior wall, interior wall, and ceiling, mainly in one room, not other areas.
