Brick Chimney That Was Covered With Plaster. - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-02-2012, 12:29 PM   #1
Brick Chimney that was covered with plaster.
In my kitchen the previous owners wall papered over a brick chimney. We did not realize this till we took down the wall paper & noticed huge chucks of plaster coming off with the wall paper. Apparently there is moister that set in and it made the plaster crumble. I am not sure what to do. Should I just replaster the area & paint over it? Or is there a better solution?
deeppurple is offline   Reply With Quote
Old 04-06-2012, 01:54 PM   #2
Drywall contractor
Rewards Points: 1,070
If there are large chunks of plaster coming off, I doubt you'll be able to just re-plaster the bad places. The integrity of the plaster is likely gone. Is it "chalky" or "sandy" feeling where the pieces came off?? New mud/plaster may not adhere. You may want to get a pro to take a look at it and advise rather than attempt to fix it and just waste your time. And above all, you need to find and resolve the moisture issue. I'm not in the plastering business, but have done some plaster repairs (with drywall materials), so you may get some more replies with better advice. Best of luck...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-06-2012, 07:11 PM   #3
Ravenworks's Avatar
I would strip the brick down and clear coat it and enjoy it brick,unless you don't like brick.
Ravenworks is offline   Reply With Quote
Brick work to repair a Chimney worthspending Building & Construction 2 10-17-2010 08:58 AM
Painted Chimney Brick Damage notalent Building & Construction 0 08-10-2010 09:41 AM
Receptacles in plaster on brick construction pmoe Electrical 4 02-23-2009 08:56 PM
electrick wire next to vent or brick chimney? ptcamaro Electrical 2 04-01-2008 11:28 PM
Addition around existing brick chimney Adenmoor Building & Construction 2 11-20-2004 11:37 PM
