Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 02-14-2010, 05:56 PM   #1
Bottom of drywall
We have an older home in which we are removing the carpet and adding laminate floors. There was paneling all along our living room wall just on the bottom half that we decided to remove. When we removed the paneling we found out that it was there to cover some problems. The main problem is the bottom of the wall, its in rough shape we were wondering if there is a way to fix it. If not can we just replace the bottom of the wall or do we have to replace the whole wall. There are chunks grooved in and corners missing. Thanks for any help given!
jessica042785 is offline   Reply With Quote
Old 02-14-2010, 06:22 PM   #2
Remodeling Contractor
Bottom of drywall
not sure what you are asking... but you can replace the bottom section of a wall only if that is what you want. keep the drywall off the floor at least a 1/2" so it does not week up moisture from the floor.
Old 02-14-2010, 10:51 PM   #3
Moderator
Bottom of drywall
In an older home the plaster may be damaged from abuse. It is easy to repair. Perhaps that is why it had chair-rail and wainscoting (http://www.elitetrimworks.com/home.php?cat=4 ) on it, someone thought it impossible to fix. Or, it could have been installed originally that way with the underlying surface not finished as the builder knew it would be hidden. A picture would be nice……..
Be safe, Gary
Clothes taking longer to dry?
Old 02-15-2010, 11:11 AM   #4
Drywall contractor
Bottom of drywall
Pull the bottom sheet and hang a new one, finish, paint, and trim.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Framing for Drywall Ceiling Wino Building & Construction 1 01-13-2010 03:05 PM
Bathroom drywall question... StevePax Remodeling 9 01-08-2010 03:30 PM
Suspend Drywall on wooden I-Beams rickkeeter Drywall & Plaster 10 11-12-2009 10:28 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
Attaching Drywall to 4" of Rigid Foam PerpetuallyRepairing Drywall & Plaster 9 02-19-2009 06:24 PM
