Bored Puppy, Big Problem - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-06-2011, 09:58 AM   #1
As the title says, I have a puppy, a six month old Border Collie. She was being kept in the downstairs powder room, and managed to chew/scrape a hole in the exterior wall, pulling out fiberglass insulation and through the sheathing until I can see the vinyl siding through the hole. All in just a couple of hours. The hole itself is about 4" in diameter. My questions are:
How do I repair the vapor barrier?
What is the best way to re-insulate?
I think I can patch the drywall, but the rest of it is what concerns me. I am hoping to keep this repair as minimal as possible, dollar wise, time wise and effort wise, as I am tight on time and money and limited on tools and skills.
Thanks in advance.
DocWard is offline   Reply With Quote
Old 08-06-2011, 10:15 AM   #2
Experienced
Jackofall1's Avatar
You first need a kennel to keep the pouch in, you will have to open the wall further, neatly cut insulation and fit in new pieces, redrywall, eat pouch, don't over cook it makes them tough
Old 08-06-2011, 10:21 AM   #3
She slept in a cage last night, and for the foreseeable future. I've eaten a lot of things in my time, from alligator to camel, but I think I will pass here. Besides, she's a scrawny thing. Not much of a meal.
Old 08-06-2011, 06:27 PM   #4
So, what should I do about the vapor barrier? Can small pieces of fiberglass be found, or would I be better off trying to make use of some sort of foam insulation?
Old 08-06-2011, 06:34 PM   #5
DIY staff
Rewards Points: 7,174
What was the outside sheathing made from? Styrofoam?
Two pictures would help--one of the damage and another one of the dog.----Mike---
Old 08-06-2011, 06:50 PM   #6
Let me see what I can do.
Old 08-06-2011, 07:07 PM   #7
The sheathing is yellow inside, with a metallic foil exterior on each side. The yellow appears to be styrofoam with what feels like some fibers in it when I crumble it, if that makes sense. It is about fifteen years old, if that helps.
My camera cord is at work in my computer bag and not with my camera where it belongs. I will try to get some on my wife's phone and post them.
Old 08-06-2011, 07:25 PM   #8
Let me see if I can do this. The results from the phone aren't very good.
Old 08-06-2011, 07:53 PM   #9
DIY staff
That dog wanted out!
Open up the wall enough to work---
Tape some heavy plastic over the damaged Tyvec using aluminum foil duct tape--
Replace any foam board if that is what's missing--once again using the duct tape.
Replace the missing insulation and patch the drywall.
O.K. now a picture of the dog!
DocWard (08-06-2011)
Old 08-06-2011, 08:01 PM   #10
firehawkmph's Avatar
Rewards Points: 1,868
In addition to what Oh Mike said, teaching the dog to sleep in the kennel is a good thing. A lot of people do that from the time they bring them home. The kennel becomes 'their' special home, a place of refuge. When dogs start really chewing stuff like yours did, or digging holes in the back yard, it usually means they need exercise. Especially a breed like a border collie. Get the dog out and let her herd up the neighborhood kids or chase tennis balls till you're tired of throwing them. They need a workout, plus it's a lot of fun.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following 2 Users Say Thank You to firehawkmph For This Useful Post:
1910NE (08-06-2011), DocWard (08-06-2011)
Old 08-06-2011, 08:07 PM   #11
Going to be a real trick from the inside, but I can probably do it. I'm assuming I am going to need to buy a full size sheet of the foam board. What about the insulation?
As for the dog, no she isn't wearing the megaphone now:
Old 08-06-2011, 08:12 PM   #12
Mike Hawkins
We also have a Australian Shepherd and a Jack Russell. We are strong believers in cage training. We were keeping the Aussie in the cage while the Border Collie was recovering from surgery, and they seemed to be dealing well with the situation, until I came home on Friday and found the mess. We live on an acre in the country and try to get them out as often as possible to run. The biggest problem is the obsessiveness of the Jack Russell and the Border Collie trying to "herd" her.
Old 08-06-2011, 08:15 PM   #13
DIY staff
It's a shame to have to buy a big sheet of foam for a little patch.
But unless you find a broken sheet in the mark down isle--what else can you do?
Nice dog--they live to be helpful she needs to be around you when you are out side.
I've had 3 Australian Sheppards--They are a lot like the border collie.
Old 08-06-2011, 08:23 PM   #14
I hadn't thought of looking for a broken sheet.
We've had two Aussies, and been very happy with them. Our current one likes to sneak upstairs. The Border Collie has already learned that isn't supposed to happen and lets everyone know about it.
Old 08-07-2011, 02:57 PM   #15
Well, I got it done. I have a nearly full size sheet of styrofoam sheathing and most of a 2x2 piece of drywall left, but those are the breaks. Where there were doubts, I taped the daylights out of it with foil tape, so hopefully I will have sufficient vapor barrier. It is in a relatively protected spot in relation to the exterior, which I hope will help. Now to just wait for the compound to dry, sand it and get it good and smooth and see if we have any paint left to match that is still liquid.
The Following User Says Thank You to DocWard For This Useful Post:
oh'mike (08-07-2011)
2 TVs fried: Electrical vs. Comcast Coax Cable Problem LynOprinka Electrical 17 07-16-2012 08:01 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 11:53 AM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 06:42 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
