Bonus Room Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-16-2009, 09:53 AM   #1
Bonus room drywall
I want to finish my bonus room over my garage. It is a pre framed truss
system with the bonus room area 12 foot wide by 8 foot high. 2 x 10
floor joist, 2 x 4 studs (5 foot high), 2 x 8 rafters. All trusses are on
2 foot centers. I have 5 different surface areas to cover, creating 4 seams. How should I go about drywalling this area that has
no top or bottom plate?
Install staggered nailers?
5/8 " drywall?
I don't want to use firring strips and I may put up sheets of wainscot
beadboard (36 -48") if I can find what I want.
Thanks,
Randy
rhall31 is offline   Reply With Quote
Old 01-17-2009, 08:26 AM   #2
Drywall contractor
Rewards Points: 1,070
You just fasten to the framing members instead of a plate. Or, you could add blocking between the framing to "create" a top and bottom plate.I would pull a string line on the walls to check for plumb. I would definitely recommend 5/8" on the ceiling at least. Start with the knee wall on one side, then stack the ceiling up from the wall. Hold the bottom wall sheet 1/2" off the floor. If you use wainscot of less than 1/2" thickness, back it with 1/4" drywall.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 01-18-2009, 11:09 AM   #3
I'll probably go with 5/8" drywall on the walls and the ceiling. I'll put
backers in when I decide what height my wainscot is going to be.
I'm in the process now of trimming and shimming everything to as square
as I can get it using string lines and levels.
What is the purpose of holding the bottom sheet of drywall 1/2" off the
floor?
Old 01-18-2009, 11:56 AM   #4
Drywall contractor
Gives you a little leeway if your floor is uneven rather than having to cut the boards different height. Just stick a couple of scrap pieces of drywall under the bottom board (5/8" will work). Also give a little room for the natural movement of the lumber during heating and cooling seasons so the joints don't "ridge". In the case of a concrete floor, you don't want the board in contact with the concrete as it will "wick" moisture.
Bonus Room subfloor rhall31 Building & Construction 2 01-06-2009 06:49 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Drywall over drywall? And a bonus flooring question! perpetual98 Remodeling 18 01-02-2008 10:36 AM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 05:33 PM
