Board Overing? Sheetrocking Over Existing Sheetrock - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-10-2010, 01:43 PM   #1
Rewards Points: 150
Board overing? Sheetrocking over existing sheetrock
If I am hanging sheetrock over top of existing sheetrock can I use 1/4" or should I go with 3/8"? Current rock is 5/8", I going over with new sheetrock just to make the walls and ceiling smooth. 1 1/4" screws ok? or 1 1/2" better?
Evil Scotsman is offline   Reply With Quote
Old 11-10-2010, 02:35 PM   #2
Drywall contractor
Rewards Points: 1,070
1/4" drywall is fine. The next size drywall screw after 1-1/4" would be 1-5/8" and would be the appropriate length to use.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
The Following User Says Thank You to bjbatlanta For This Useful Post:
Evil Scotsman (11-10-2010)
Old 11-10-2010, 02:55 PM   #3
Rewards Points: 150
THANK YOU VERY MUCH!
Installing backerboard - replace particle board? salvop Flooring 10 04-29-2011 10:32 PM
Ridge Board Support Dilemma castlerock Building & Construction 2 01-06-2009 06:57 PM
Any experience with Dupont Real Touch elite laminate flooring? danidisney Flooring 12 08-24-2008 03:22 PM
Ridge board enough? runningforyou Roofing/Siding 9 08-13-2008 07:43 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
