Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 03-03-2011, 10:03 PM   #1
Blue lid exclusively?
I have read lots of advice on drywall mudding here and have learned quite a lot. I have a guy who insists on using premix blue lid throughout the process- nothing between the joints under the tape, bedding the paper tape in blue, finishing in blue.
My understanding is the blue lid is supposed to be for the finish coats only. What sort of problems can I expect from the above-mentioned technique?
Jim F is offline   Reply With Quote
Old 03-04-2011, 06:03 AM   #2
Super Moderator
Lifting paper and cracks----You have a novice there---
I know that you have read up on this,so this is for others----
Durrabond (bag mix) is used to pack cracks and voids
Green lid--(all purpose) loaded with glue--Used to set paper---
Blue lid--(light weight) easy to sand--used for final coat
oh'mike is online now   Reply With Quote
The Following 3 Users Say Thank You to oh'mike For This Useful Post:
crankcase (03-04-2011), Jim F (03-04-2011), Willie T (03-04-2011)
Old 03-04-2011, 06:38 AM   #3
Hey Mike I have a question what about the dust control stuff. I've been using that stuff with great success is there any precaution using that stufff. I water it down a bit as it is quite thick but it goes on nicely and sands good too. Thanks
ryan5068 is offline   Reply With Quote
Old 03-04-2011, 09:24 PM   #4
Super Moderator
I've used it a couple of times----Seems to be a good product---However,I'm a nut for tarps,plastic and other protection and didn't feel that the premium cost was worth it for my style of working.--Mike--
Old 03-05-2011, 04:13 PM   #5
Drywall contractor
I personally don't use lightweight (blue lid) at all because it scratches too easily (doesn't set as hard). Many swear by it, but it is meant for skim only. Tried the dust control once when it first came out and didn't particularly like it (just the way it went on, not the dust control part). I use a sander with a vac system so dust isn't really an issue...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Should I replace my blue board after it got wet from a water heater leak? petep Drywall & Plaster 4 07-11-2010 10:44 PM
Fanimation ceiling fan question: no blue wire from ceiling camrn2006 Electrical 8 03-07-2010 01:19 AM
Masking and Blue tape ripping off paint LeviDIY Painting 20 10-21-2009 07:56 PM
Working with a Blue tub...yikes captainobvious Interior Decorating 6 10-12-2009 09:48 AM
Got a dark blue mess on my hands... pk1023 Painting 6 09-14-2009 09:30 PM
