Blister In The Tape - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-23-2011, 07:11 PM   #1
Rewards Points: 27
Blister in the tape
I finished finishing my drywall the other day and primed it today. Got all done and noticed that somehow through this whole time i have missed the fact that i have a blister in the tape on one joint in the room. like i said the room is primed. was wondering what the easiest way to fix this is. whether i should cut it out and mud it sand it and re prime it or if there is a different way. thank you
Conde54 is offline   Reply With Quote
Old 06-23-2011, 08:51 PM   #2
Blister in the tape
What you described is the best way to repair the blister. Instead of cutting out the blistered portion of the tape, you should be able to make a slit through the paper and then work drywall compound behind the tape. This should make it easier to blend the repair into the original finish. If you have already textured the wall, you should also touch-up the texture. Otherwise the smooth repair patch will be obvious after painting.
David
Jessidog is offline   Reply With Quote
Scotch Edgelock Tape: My afternoon entertainment bokeh Painting 5 06-20-2011 10:17 PM
Effects of electrician tape on cable richard7994 Electrical 4 08-11-2010 09:39 AM
Paint problems....or just problems with the painter... deanswife Painting 5 07-30-2010 09:36 AM
Aged Painting Tape Needs to Come Off user1007 Painting 2 03-04-2010 06:16 PM
Masking and Blue tape ripping off paint LeviDIY Painting 20 10-21-2009 07:56 PM
