Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 04-07-2011, 01:11 PM   #1
Blend Hardiboard with Drywall
We are having a shelf put into our shower (two 2x4s nailed between the studs) and there currently is no drywall on the other side of the wall. Because of this there is nothing to mount the hardibacker to. If the tile guy were to put 1/2 inch hardibacker screwed to the back side of the wall where drywall would normally go, would someone be able to drywall around this, then skimcoat the whole thing to look like one uniform wall? Basically there would be 1/2 inch drywall with about a 12"x12" square of 1/2" hardibacker that all needs to blend? Any other better ideas?
Thanks,
Richard
rjschwar is offline   Reply With Quote
Old 04-07-2011, 03:04 PM   #2
Drywall contractor
If you're planning on finishing the other side of the wall eventually, why not go ahead and hang it now and attach the Hardie board to it rather than the other way?? You could probably use a waterproof membrane and eliminate the Hardie. I'm not a tile man, so I'm not positive on that. Yes, the Hardie could be skimmed and painted, but it will always look like a patch if not done properly. Wouldn't want that in the middle of my wall if it wasn't necessary.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-07-2011, 03:34 PM   #3
I may go out and get a single piece of drywall and hang that. We had a guy skim coat our living room which was lathe and plaster and had lots of holes. He patched the holes w/ drywall and left the plaster that was solid. This looks great, and you can't see any seams where the two meet. I was hoping this would be possible w/ the hardyboard so I don't have to hang the drywall now in case I want to run wires in that wall. I guess I can try and rout around this area. Is there any trick to hanging drywall? If I am just haning this one peice, should I just line it up w/ the edge of the wall and screw it into the studs?
Thanks,
Richard
Old 04-07-2011, 06:53 PM   #4
Drywall contractor
If you've got someone doing the work and you're pleased with the results so far, then I'm sure it won't be a problem. Sometimes it's a bit tricky for a DIY'er. You might call him and get his opinion.....
Old 04-07-2011, 06:57 PM   #5
The think is the guy that did the work moved to colorado. I am going to have someone else do the drywall most likely, but if there are no other suggestions, I'll just hang the one piece and let whoever finishes it match to that. Is there any issue w/ this?
Thanks,
Richard
Old 04-07-2011, 07:03 PM   #6
Drywall contractor
That's probably your best bet.
Old 04-07-2011, 07:33 PM   #7
Great, thanks.
Richard
Old 04-07-2011, 09:54 PM   #8
Tileguy
Bud Cline's Avatar
The Hardibacker is really only 7/16" thick so you'll have more patch than you realize, not a major deal tho.
The Hardi will have to be waterproofed on the shower side.
First-timer drywall install-LONG- Axhammer Drywall & Plaster 8 04-17-2011 10:02 AM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 10:42 PM
Old ceiling replacement idsp General Discussion 12 07-25-2009 11:48 AM
