Best Way To Seal Gap In Drywall Around Recessed Lighting Trim - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-18-2013, 01:50 PM   #1
Best way to seal gap in drywall around recessed lighting trim
Hi All,
I have a recessed can that has a gap in one area that is bigger then the trim. Can anyone recommend what I should use to fill in this gap? I assume it should be non-flammable as it may touch the can itself, but that's about all I know. Please see the attached picture for what the gap looks like.
http://imageshack.us/photo/my-images/28/bk0g.jpg/
I am not a do it yourself by nature, but want to tackle this on my own. Would caulk be the right product to fill in the gap? Would I remove the trim first before caulking or just leave the trim in place and fill in that gap?
Adam
TangledUp is offline   Reply With Quote
Old 06-18-2013, 07:29 PM   #2
Rewards Points: 13,458
The right way would be to cut a square section of that drywall and fill it in with a patch and this time drill it out with the right sized hole saw this time.
But you could use hot mud to try and fill in the gap. Going to have to remove the trim ring first.
Old 06-18-2013, 07:34 PM   #3
General Contractor
CENTERLINE MV's Avatar
Agreed. Hot mud or joint compound if you're not comfortable with mixing. Looks small enough where you don't need tape.
CENTERLINE MV is offline   Reply With Quote
Old 06-18-2013, 07:39 PM   #4
When you say hot mud, what do you mean?
For joint compound would I use one of these?
http://www.amazon.com/10102-Wallboar...joint+compound
http://www.amazon.com/12374-CrackSho...joint+compound
As you can see I am clueless with this stuff, but willing to learn!
Old 06-18-2013, 07:44 PM   #5
Rewards Points: 22
Hot mud is drywall compound that must be mixed with water. It hardens by a chemical reaction which is why it must be mixed with water before it is used. It comes in various setting times ranging from 5 minutes to 90 minutes.
http://www.homedepot.com/p/SHEETROCK...0#.UcD-m5zNnGA
You could use premixed joint compound. You'll have to wait at least 24 hours for it to get good and hard.
Dan
djlandkpl is online now   Reply With Quote
Old 06-18-2013, 07:59 PM   #6
General Contractor
http://www.amazon.com/USG-Corporatio.../dp/B008XKW06G
Old 06-18-2013, 08:41 PM   #7
Thanks for all the info. I think it would be safer/easier for me to just use the joint compound. This stuff is safe to sit against the hihat container, which may get hot?
Old 06-18-2013, 08:47 PM   #8
CitadelBlue's Avatar
Rewards Points: 97
Take the trim ring off and apply several layers of joint compound (a little at a time) several times, several hours apart and a little at a time ...
Did I mention " a little at a time .....
CitadelBlue is online now   Reply With Quote
Old 06-18-2013, 09:45 PM   #9
General Contractor
Yes, it'll be fine. JC is not combustible. As advised above, take trim ring off and apply several small coats rather than fewer heavy coats. Make sure each coat dries completely before applying the next or it'll crack. Sand lightly between coats if necessary.
Old 06-18-2013, 10:08 PM   #10
Rewards Points: 6,652
What do you think is in between the paper. Same stuff is what comes in the dry mix, but also has more Plaster of Paris in it. If those fixtures get too hot, there is actually a sensor inside them that shuts them off at a set temp.
Old 06-19-2013, 07:53 AM   #11
Thanks for the information everyone!
Recessed lighting trim interchangability? Badfish740 Electrical 5 11-28-2012 01:39 PM
installing recessed lighting trim lwb1 Electrical 1 09-01-2010 08:43 PM
Cover for Recessed Lighting Trim Model HBR635(T49) aghahary Electrical 4 07-23-2010 04:30 PM
Removing trim from recessed lighting dadaR6 Electrical 3 02-09-2009 01:52 PM
recessed lighting in basement DIY4EVER Electrical 6 06-29-2007 02:52 PM
