Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 12-18-2008, 06:42 AM   #1
When is fishing season?
CowboyAndy's Avatar
Best way to patch holes in drywall
What is the best way to patch a hole in drywall? I have done new sheetrock and mud before, but never had to patch a hole. There are 2 holes, 1 is 6"x6", then about 3" below is a 4"x4" hole.
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 12-18-2008, 07:44 AM   #2
gravity always wins
Paint stores have adhesive patches that stick on and then mud over. Around here they sell them in 4x4 and 6x6 versions. The other way is to screw a couple of wood blocks across the inside of the hole and screw a patch to the blocks. Then mud and tape.
Old 12-18-2008, 08:05 AM   #3
cut a piece of drywall 4" bigger then the hole turn over to the back side of the drywall cut paper on back 2" or little more in oround the sides bend or break the broad on the cut peal off the outer backing you have a peice that will fit the hole and have paper side to mud and finsh no wood or other things need mud edge of hole put you peice in place mud like any taped seam
colddodger is offline   Reply With Quote
Old 12-18-2008, 09:01 AM   #4
Moderator
Termite's Avatar
I don't care for the band aid patches they sell. Weak repair at best, although aesthetically they look the same.
I prefer to use a couple pieces of 1x a few inches longer than the hole. Insert them into the wall and run a screw through the sheetrock an inch or so from the edge of the patch into each end of the 1x's. That gives you something solid to screw a new chunk of sheetrock into, giving you a solid, stable full thickness patch that isn't reliant on tape to hold it in place.
Old 12-18-2008, 10:06 AM   #5
Drywall contractor
Colddodger's method (hot patch) is the easiest for small repairs. Put a small amount of mud around the edge of the patch and the hole in the wall. Wipe all excess so the patch doesn't bulge out. Allow to dry completely before coating again (12 hrs. or so). If you use setting type compound, you can speed up the process.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 12-18-2008, 12:55 PM   #6
I have used these clips numerous times and they work great and are pretty cheap. You just slide them onto the drywall already in place and drive a screw in and then cut your new piece of drywall patch and put it in place and then screw it to the clips and then the tabs on the clips break off. Super easy and leaves a flat surface to tape and mud.
http://www.prest-on.com/Scripts/prod...p?idcategory=3
ponch37300 is offline   Reply With Quote
drywall patch over pocket door kninja1211 Drywall & Plaster 3 06-26-2008 12:34 AM
Need to fill nail holes in drywall, what to use? twilightcall Building & Construction 3 05-12-2008 09:20 PM
small holes in drywall mud kimmyb General Discussion 5 01-26-2008 10:21 AM
How to patch screw holes in metal door? tima2381 Carpentry 2 05-02-2007 08:23 AM
Texturing drywall patch? Doug Crf Remodeling 4 09-21-2006 08:54 PM
