Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 07-08-2008, 01:41 PM   #1
Best way to hang drywall?
Ok, my garage has a 10' walls with 16" OC studs and I have drywall that is 4x12'. Is it better to hang the drywall horizontal or veritcal? Vertical I have to cut 2' off and only one vertical seam. Horizontal, I don't cut any off the sheet (other than the piece to fill in the 2' void), but have two seams horizontal? Advice? Thanks.
737Pilot is offline   Reply With Quote
Old 07-08-2008, 03:15 PM   #2
Licensed Contractor
Horizontal. I hate vertical seams. Horizontal seams are easier to do, imo.
Somewhere I've read/heard where DW is meant to be installed horizontally, but I've never gotten any hard evidence for or against it.
Renovator,LLC is offline   Reply With Quote
Old 07-08-2008, 04:20 PM   #3
Moderator
Termite's Avatar
Horizontal for sure! I can't imagine taping butt seams vertically, although some people do it.
Old 07-08-2008, 04:46 PM   #4
Licensed Contractor
If he's hanging the rock vertically, there should be no butt seams, right? He cuts off 2 feet off the top, and there's a single TE seam, or that's the impression I get.
Old 07-08-2008, 04:49 PM   #5
The Big Builder
I have done both with good results. I would say do what ever lowers the amount of taping is the route I would take. I am sure it will turn out fine. If not, you will have to but some new tool chest and shelving unit to cover it up.
bigbavarian is offline   Reply With Quote
Old 07-08-2008, 05:23 PM   #6
Moderator
Termite's Avatar
I should have said that the tapered edge seam is easier to mud and tape in the horizontal position. Renovator's right...The "butt" seam would be the ends without the taper.
I still vote for horizontal.
Old 07-08-2008, 06:19 PM   #7
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
10 foot walls: Generally, we will only stand sheets up on steel frame commercial and industrial applications.
On wood frame, we lay them horizontally 99.9% of the time. The best method when you have that additional 2' section, is to start hanging at the top with full sheets, and place the 2' strip sections at the bottom (cut end down). At 2' +, that seam should still be easy to reach, coat, and sand, unless you are incredibly tall, and bending over to that point is difficult for you. This way: All seams are "factory edges" -to- "factory edges".
- Build Well -
Old 07-08-2008, 10:51 PM   #8
BUILDER / REMODELING CONT
buletbob's Avatar
I Say horizontally, I feel it helps keep the wall straighter, Do they have 5'x12' sheets by you. BOB
Old 07-08-2008, 11:26 PM   #9
Thanks for the replies everyone. I will definately go horizontal then. No 5'x12' sheets that I know of, though that would be nice.
Old 07-09-2008, 08:18 AM   #10
Example:
- Build Well -
Old 07-09-2008, 08:57 PM   #11
liscenced electrician
ya, ive always hung my drywall horizontal on the theory that it will tie the studs together better
jimmy21 is offline   Reply With Quote
Old 07-10-2008, 03:52 PM   #12
With a checkbook!
Glid is offline   Reply With Quote
Old 07-11-2008, 11:25 PM   #13
Talking
Stability, easier seams. Prefer to start at the bottom, then the second sheet is held up by the first, and so on. When doing ceilings, I go and hide.
$hoop is offline   Reply With Quote
Old 07-20-2008, 08:22 AM   #14
HomeAdditionPlus.com
I would highly recommed hanging the sheetrock horizontally. Start by hanging sheets at the top and working your way downward. Small strips should be near the bottom, as they are more difficult to see when walking into a room.
Last edited by AtlanticWBConst.; 07-20-2008 at 01:58 PM. Reason: DIY Chatroom Rules Violation: Site Link Removed
mjdonovan is offline   Reply With Quote
Old 07-20-2008, 08:30 AM   #15
Drywall and Painting Pro
Sir MixAlot's Avatar
Definitely horizontally!
Checkout some of
Sir MixAlot is offline   Reply With Quote
Cost to Drywall hang/finish...please read, good explanation Firehawk734 Remodeling 63 12-17-2012 10:29 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
how do you hang drywall 20+ feet in the air? johnny331 Drywall & Plaster 8 07-22-2008 10:06 PM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 04:00 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
