Best Tools For Drywall Removal? - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-21-2011, 09:57 AM   #16
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Drywall of 5/8" thickness is a typical "code minimum" for ceilings most everywhere I know of. Has to do with fire protection.
XXX
The Following 2 Users Say Thank You to Bud Cline For This Useful Post:
DangerMouse (12-21-2011), Jay 78 (12-21-2011)
Old 12-21-2011, 09:57 AM   #17
the Musigician
DangerMouse's Avatar
Originally Posted by Jay 78 View Post
Why is 5/8" required?
It's possibly not required for him, but 5/8" Fire-X WAS required for my home as I built it. I believe it's code everywhere though.
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
Jay 78 (12-21-2011)
Old 12-21-2011, 10:00 AM   #18
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
You always put 5/8" on the lid
titanoman is offline   Reply With Quote
Old 12-21-2011, 10:01 AM   #19
the Musigician
oh'mike and I were just talking on the phone (he was on his way to breakfast with a friend/client) and he suggested throwing down some visqueen plastic before you start! I have to agree! Then when you're done, just roll it up and dispose.....
This WILL be a messy project, guaranteed!!
DM
Old 12-21-2011, 10:03 AM   #20
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I should have also added that 5/8" won't sag (between the rafters) as quickly as 1/2" will.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
Jay 78 (12-21-2011)
Old 12-21-2011, 10:08 AM   #21
Originally Posted by Bud Cline View Post
3/4"..............
It's actually 1 5/8". Clips + channel.
neo95gt is offline   Reply With Quote
Old 12-21-2011, 10:25 AM   #22
And yes, 5/8th is code for me. I'll be actually adding 2 layers of 5/8th.
Old 12-21-2011, 10:31 AM   #23
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Okay...but why?
XXX
Old 12-21-2011, 10:42 AM   #24
Okay...but why?
Sound proofing reasons.
Old 12-21-2011, 11:01 AM   #25
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Got it!
XXX
Old 12-21-2011, 11:15 AM   #26
Rewards Points: 178
Are you going to use Green Glue between the drywall boards?
It's good to be learning all of this. I'm going to be tearing drywall out of 2 rooms in my basement soon.
Instead of taking the drywall screws out of the studs, would it be alright to use a multi-tool or a Sawzall to cut them off?
Also, would it be alright to use a circular saw to cut a line in the drywall from one end to the other between the studs? Of course, with the blade set slightly deeper than the thickness of the drywall to avoid hitting electric wires. I'm sure there's a reason why that won't work, but thought I'd ask.
gma2rjc is offline   Reply With Quote
Old 12-21-2011, 11:18 AM   #27
Disabled wood vet
titanoman's Avatar
Why wouldn't you be able to cut the screws?
Using a saw...if you want dust everywhere.
Old 12-21-2011, 11:24 AM   #28
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Those screws are super-hard. Not sure with the cost of blades for Sawzalls and Multi-tools it would be worth it.
XXX
Old 12-21-2011, 11:27 AM   #29
the Musigician
CLOUDS of dust! OODLES and BOODLES of dust!
I'd NEVER try to use power tools to cut drywall..... whatta mess!
DM
Old 12-21-2011, 11:33 AM   #30
Rewards Points: 178
I hadn't thought about the dust. Hmmm. I don't know if I have the strength in my hands to pull down drywall. I guess I'll find out .
The Sawzall blades would probably be the cheaper of the two. Multi-tool blades are fairly 'spensive.
Tools for a newlywed beginner mephysteaux General DIY Discussions 9 09-24-2010 11:43 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
Lead paint removal Luken8r Painting 3 05-15-2008 08:05 PM
Bought tools today, good or bad deal? Mr. Michael Tools 3 02-13-2007 01:39 PM
