Best Tools For Drywall Removal? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-20-2011, 11:01 PM   #1
Best Tools for Drywall Removal?
So I'm starting a new project where I will be replacing the ceiling in a few rooms. Removal of the drywall ceiling seems simple enough, as is most demo.....But does anyone have any pointers/link to the best tool for the job? I have a drywall saw and dremel. I don't have a sledge, but for the ceiling I dunno if that would be the best tool for the job anyway. Is there any sort of must have drywall removal tool?
Also, for all the screws that will remain stuck in the joists....what is the easiest way to remove them? Simply unscrew them out if the screws aren't too mudded up, or is their a good tool I can use to just rip them out (if possible without causing too much damage).
Thanks for any tips.
neo95gt is offline   Reply With Quote
Old 12-21-2011, 01:25 AM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Two hands are your best removal tools after punching a few strategically located holes.
A crow bar will remove the screws easily.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
oh'mike (12-21-2011)
Old 12-21-2011, 05:03 AM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Don't forget there's insulation above.
If you are going to go into the attic to do something with this anyway, I would kick the drywall down from up above, if this can be done safely.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-21-2011, 05:55 AM   #4
the Musigician
DangerMouse's Avatar
If you use a bar and rip the screws out, they'll tear up the truss chords as they come out. Personally, I'd rip the drywall down, then unscrew. If they're plugged with mud, use some small vice-grips to remove them.
DM
Old 12-21-2011, 06:18 AM   #5
Disabled wood vet
titanoman's Avatar
DM
What about smacking them back and forth with a hammer until they break?
Old 12-21-2011, 06:26 AM   #6
the Musigician
That'd work too, but if it were me, I'd unscrew and clean them up and recycle them! (I'm cheap! ) I'd also be concerned about not having a smooth, flat surface to reattach to.
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
dougp23 (12-25-2011)
Old 12-21-2011, 08:15 AM   #7
Thanks for the responses guys. I figured as much, looks like I should get a heavy duty crowbar and some gloves and have at it!
Old 12-21-2011, 08:23 AM   #8
the Musigician
Ceiling drywall screws are required to be longer than the ones used on walls. If you crowbar them out, you'll almost certainly tear up the wood, making it weaker and less likely to have a good surface to re-screw to when you replace the required 5/8" drywall. If you do not want to reuse them, then I'd be inclined to go with titanoman's suggestion and break them off.
DM
Old 12-21-2011, 08:24 AM   #9
DIY staff
Rewards Points: 7,174
A simple flat bar is plenty---be sure to knife the corners --so you don't damage the walls as the drywall is removed.
Old 12-21-2011, 08:25 AM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Phooey !!!
There will be plenty of meat remaining for the new screws. Drywall screws are never that healthy to begin with. Scrape the splinters and go for it.
XXX
Old 12-21-2011, 08:26 AM   #11
the Musigician
Ceilings Mike....
DM
Old 12-21-2011, 08:27 AM   #12
the Musigician
Okay, whatever you guys say. But of course, you know I'm right......
DM
Old 12-21-2011, 08:36 AM   #13
DM
Good point. Now that I think of it, I will be hanging my new ceiling using clips and a hat channel (this is a sound barrier project). So I probably can just leave the screws in there since there will be a 1.5" gap between the bottom of the joists and the ceiling.
Old 12-21-2011, 08:46 AM   #14
Tileguy
Bud Cline's Avatar
Rewards Points: 558
3/4"..............
XXX
Old 12-21-2011, 08:52 AM   #15
Learning Things Every Day
Jay 78's Avatar
Why is 5/8" required?
Under Construction
Jay 78 is offline   Reply With Quote
Tools for a newlywed beginner mephysteaux General DIY Discussions 9 09-24-2010 10:43 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 06:12 PM
Lead paint removal Luken8r Painting 3 05-15-2008 07:05 PM
Bought tools today, good or bad deal? Mr. Michael Tools 3 02-13-2007 12:39 PM
