Best Thick Application Over Latex Based Drylock Waterpoofed Concrete Basement Wall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-01-2011, 11:01 AM   #1
Best thick application over latex based drylock waterpoofed concrete basement wall
What is best stucco or joint compound or other thick finish to apply over previously latex based waterproofed basement concrete walls?
gfccpa is offline   Reply With Quote
Old 12-01-2011, 11:11 AM   #2
Rewards Points: 13,300
What is it your really trying to do? If you trying to go for a smooth wall I'd use more Dri-Loc applyed with a wide roofing brush then wipe over it with a 14" drywall knife, A few coats and it can look like drywall, not leak and should never get brown stains like you would if you tryed stucco or plaster.
Dri-Loc can also be tinted.
Hole in concrete basement wall... viggen Building & Construction 1 06-06-2011 09:32 AM
my concrete retaining wall has a major crack where the wall has now shifted DanDaMan Building & Construction 1 04-02-2011 12:34 PM
concrete stub wall daltinator Building & Construction 2 03-29-2011 09:58 PM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
