-   -   Best taping and finishing tool kit (http://www.diychatroom.com/f101/best-taping-finishing-tool-kit-63217/)
spiral 01-30-2010 08:17 PM
Hi everyone
I am taping and finishing a room for the first time.
What are ALL the tools that I need to make it easy?
I'll be using paper tape and allpurpose mud.
I will be using Bullnose Corners. How much should the drywall be set back from the corner?
Thanks Spiral
oh'mike 01-30-2010 08:52 PM
The best tool for this is the telephone--Call a taper !!! Ha Ha .
If you are going to hang the job your self--
Ruler-drywallers knife-rasp-square-dry wall foot jack-roto zip-screw gun-drywall lift-small crown stapler?
To tape--Buy these from a drywall supplier (AAMES is one) you will not find acceptable tools at the big box stores IMO--
Mud pan(round bottom if you can)-6"--10"--12'' blades--Mud mixer and 1/2 inch drill.
Stick sander--hand sander--large sanding sponges--masks.
Here is a short list of the muds---Durabond(bag mix) 20-45-90 minute setting time-Used to fill gaps
some like to set the paper with it--Very hard -not easy to sand
Green bucket---Loaded with glue--used only to set the paper--Usually thinned a bit with water before use.
Blue bucket--Used for final coats--Easy to sand--slow to dry.
This is way over simplified but will give you a starting point----MIKE---
Kevin M. 01-30-2010 09:56 PM
Originally Posted by spiral (Post 391938)
Hi everyone
Thanks Spiral
You may want to check out this link. Lot's of good info.
http://www.drywallschool.com/
user1007 01-31-2010 04:07 AM
I subcontract almost all my drywall work out these days. Att 55 I just don't find maneuvering 5/8" sheets of the stuff to be the fun it used to be.
Every now and then I do have to do a little project though. I find corner finish tools---inside and outside---to come in handy. I have nice ones I did not buy at a box store.
I also have this almost worthless plastic combination 12-14" knife thing that has never touched a wall. The silly thing is great for mixing dry mud in a pan though.
There is also this stuff called No Pox that comes in quarts. It really speeds tool clean up and does pull a lot of the pock marks out of the mud.
spiral 01-31-2010 05:48 AM
Thanks for the replies...
The taper that I like is busy right now. I have some other things to do before I get to this. He also insists on hanging his own board.
http://www.drywallschool.com/ - i have looked at this site and many other videos on youtube and google. They make it look easy!
Spiral
oh'mike 01-31-2010 07:01 AM
Spiral--The good tapers make it look so easy--------
That is one trade that you learn only by doing. I'm a remodeler--I'm only a fair hand at taping--I'm to slow.
I hire out all of the larger jobs.
Most tapers will not work on homeowner hung rock-- I would not touch it either--There are a lot of things to learn about hanging rock properly.
Best of luck with your project--Mike--
spiral 01-31-2010 06:22 PM
There are a lot of professionals out there that also do sloppy work and do not know what they are doing. So he prefers to hang the board himself.
The one thing I have heard about taping is that is best to learn on someone else's house. Some house that you will not see again!
Spiral
oh'mike 01-31-2010 07:43 PM
You got me laughing!
oldrivers 01-31-2010 09:40 PM
No no no this is not true, the best way to learn is to hang out with a taping crew agree to work for cheap if you can help out by learning a little at a time. most crews are strapped for profit because of the cuthroats everywhere so alot of tapers dont want to deal with teaching it , but if you know some tapers see if you can learn by hanging with them doing little at a time. you do not want to go to someones house and screw it up thats not fair to them... best way is to join a crew and take your lumps.
bjbatlanta 02-04-2010 11:14 AM
I finish other people's hanging at times and it often costs them as much as if I hung and finished it...
