-   -   Best option for walls in kitchen, after removing tile? (http://www.diychatroom.com/f101/best-option-walls-kitchen-after-removing-tile-168051/)
anthony187 01-02-2013 03:29 PM
So my house was built in the 50's the tile comes half way up the wall. I want to tear this down. My only problem is after that then what. The house is all plaster. I know that under this tile is plasterboard. I am not skilled enough to skim it myself and make it look good after I take the tile down. I was thinking about trying to order 1/8" drywall and cover the two walls that this tile is on. I need some help. I am doing this on a very small budget. Any suggestions would be great. Also I work two jobs so I really don't have the time to for a huge project. Something I can do on a weekend so that my kitchen isn't out of commission for a couple weeks. Thanks for you help in advance.
pro handyman 01-02-2013 03:34 PM
Well I got an idea for you that I see in a house I was working in the other day. The customer had put new laminate on floor. They some left over and put it on walls for a back splash. I thought it look good and would be easy to do.
joecaption 01-02-2013 03:34 PM
No such thing as 1/8 drywall, it will be 1/4.
No way can a first time DIY is going to be doing this over a weekend.
It's going to take three coats at least of drywall compound, sanding, priming, and two coats of paint.
Even using hot mud it will take about 4 days min.
ToolSeeker 01-02-2013 05:28 PM
Look into different styles of wainscoting. You can get 1/8" breadboard at the box store in 4x8 sheets cut in 32" pieces raise from the floor the width of your baseboard then put a chair rail on top if painted doesn't look bad.
