Best Method To Remove Old Texture - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-16-2010, 09:15 PM   #1
Best method to remove old texture
I need to install new drywall against existing textured drywall. What is the best tool or method to make room for the new tape on the existing textured wall?
a08303 is offline   Reply With Quote
Old 07-17-2010, 11:10 AM   #2
Drywall contractor
Rewards Points: 1,070
Not quite following. Do you mean you are going to re-tape a joint or hang new drywall??
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 07-17-2010, 12:32 PM   #3
Thanks for your reply. I had water damage in my basement and they had to cut the bottom 2 ft of drywall from the floor up, so now I have to install new drywall and get rid of the texture on the existing drywall so I can tape and finish. Does that make sense?
Old 07-17-2010, 01:31 PM   #4
Drywall contractor
Got it! Use a paint scraper to get the worst off (about 6" or so up the existing drywall). Be careful so as to not gouge or tear the paper on the drywall. Then sand with 80 or 100 grit paper. That should get it smooth enough to tape and finish. Any roughness that's left will be covered with mud as you do your finishing.....
primer not adhering to drywall texture? eli_carson Drywall & Plaster 13 07-25-2013 09:00 AM
Applying texture on smooth cement interior walls Flt_Simulation Remodeling 8 05-14-2009 06:23 PM
Ceiling Texture soggycashew Painting 8 05-02-2009 09:14 AM
prime then texture or texture then prime jeerme Painting 8 01-23-2009 10:25 AM
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 04:38 PM
