Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 03-22-2011, 04:56 PM   #1
Bathroom Wall Texture Issue
We are getting ready to paint our bathroom and are very confused about what to do with the walls. They are somewhat textured (not a alot, similar to probably a lot of houses where they are just slightly textured). There are a very spots that we need to sand down first where the old toilet paper holder was, etc, and I'm pretty sure that when we sand and spackle these areas these spots will look pretty uneven from the rest of the room. Any advice? Am I stuck with sanding down all the walls (seems like a waste of time). Any help would be greatly appreciated!
hami0152 is offline   Reply With Quote
Old 03-24-2011, 11:58 AM   #2
Matching existing texture is an art. It is very hard to make it look like there was nothing done. Most of the time you hope for the end result to be that it is not noticable to others even if you know it is there. There are various ways to get a better looking job, it depends on how much time and effort you wish to put in. One, like you said, you can sand down the existing texture and retexture. Two, skim the surfaces making it smooth or then retexturing. Third, texture the patches, then retexture the whole room again, so a new texture sits on top of all the surfaces in the room to get it to blend. And fourth, just spot texture those areas in question to try and blend to the existing texture, which is the simpliest and easiest. If you haven't any experience, then you will find it hard to do any of them! But if you are young and want to learn, and might use the experience in the future, then it is worth the effort. For small patches, they have texture in a can. Practice will help before you attempt the final touches. For larger jobs, texture machine can be rented.
redmanblackdog is offline   Reply With Quote
Old 03-24-2011, 12:29 PM   #3
Can you take a picture of the texture?
pyper is offline   Reply With Quote
Old 03-25-2011, 08:44 PM   #4
what type of tezture do you have popcorn, nock down, or sun burst this will help to determin how and what will be best fix the easiest is to fix repairs then sand down to smooth then sheer coat to smmooth walls unless you love the texture then redo the texture its your choice on how much work you want to do
lrobertstoner is offline   Reply With Quote
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 07:23 PM
Framing Shower Wall in Bathroom Justin LaRue Kitchen & Bath Remodeling 2 06-30-2009 11:34 PM
Foundation/Outside Wall Issue billinak Building & Construction 4 12-02-2008 01:15 PM
How to diagnose problems with wall kahlan General Discussion 5 10-22-2008 10:18 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
