Bathroom Restoration - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-29-2010, 09:44 AM   #1
Bathroom restoration
Hi Everyone,
I'm preparing to gut a 45 yr old bathroom that is in desparate need of restoration. I'm planning to tear the tile shower surround out and replace it and the tub with a two piece FRP unit. When installing the tub and surround, I'm assuming I need to hang drywall behind it, as right now there's tile, lath, and concrete (which I'll obviously tear out). What should I use to seal the drywall? That is, should I prime it, paint it, and then glue in the surround?
grumpyhessian is offline   Reply With Quote
Old 10-29-2010, 04:23 PM   #2
You don't "need" to put drywall behind it, but it may sound a little hollow if you don't (if that makes sense.)
if you do put drywall behind it, i would use the moisture resistant kind, but i would not worry about painting it.
1910NE is offline   Reply With Quote
Old 10-29-2010, 08:02 PM   #3
DIY staff
Rewards Points: 7,174
Look at the installation instructions--Most of thos are nailed directly to the studs---then drywalled around the edges--after you add some thin furring strips (to keep the drywall from bulgung as it lands on the fiberglass lip)
Old 11-07-2010, 11:07 AM   #4
Drywall contractor
Rewards Points: 1,070
Mike is correct. I've never hung drywall behind a shower enclosure.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 11-08-2010, 08:03 PM   #5
Ok, thanks guys. Yeah, I don't recall ever seeing drywall hung behind a shower enclosure, but I just couldn't remember for sure. I may still put some sound insulation in between the studs since the den is on the other side of the wall.
Basement bathroom rough in efrobert Plumbing 2 06-23-2011 05:54 PM
Bathroom DWV Layout Problems grymes56 Plumbing 8 05-15-2011 10:00 AM
Bathroom fan replacement reveals...a mess merlanvp Electrical 0 07-25-2010 09:00 PM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 10:29 AM
Plumbing Help for New Basement Bathroom morphers82 Plumbing 2 03-14-2009 01:17 AM
