Bathroom Remodel (sheetrock Wall Question) - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-14-2011, 06:57 AM   #16
Cement board may be a better choice for the shower walls. I am not an expert. Maybe someone else can provide an opinion.
beerdog is offline   Reply With Quote
Old 04-14-2011, 12:08 PM   #17
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Beerdog has a point. Proper procedures for shower walls will be different. They need a level of waterproofing that the regular walls don't. To get accurate advice people here need to know what walls you are talking about.
Old 04-14-2011, 12:23 PM   #18
the shower wall can be sheetrock because I am using onyx to cover it.
ingeborgdot is offline   Reply With Quote
Old 04-14-2011, 06:26 PM   #19
Registered User
Rewards Points: 5,498
Can you progressively furr out the wall opposite the tub side, to the corner? May not work if ever installing tile or pattern on floor where it would be noticeable... Will not work at door.
Could cheat 1/4" by dadoes at the back of drywall exactly at high side of pipe, utility knife and chisel/gouge. Only 1/4" off in end.
Gary
Old 04-22-2011, 07:44 AM   #20
vent problem
i would ask does this pipe go all the way back to the other wall or is there some working room if so set back the duct work or you can replace it with a more friendly unit that will fit inside your wall
see how that works for ya
lrobertstoner is offline   Reply With Quote
Old 04-22-2011, 08:53 AM   #21
Almost, but there is the floor joist that is holding it up from moving back any farther. I already looked at that situation.
Sheetrock And Insulation Question kn1564 Remodeling 4 04-23-2010 11:24 AM
bathroom sink & wall dknarnd Remodeling 1 01-24-2010 10:56 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 04:48 PM
Mounting a flatscreen TV on a sheetrock wall TanMan Building & Construction 14 02-16-2009 04:26 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
