Bathroom Exhaust Fan Location In Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-01-2011, 05:47 PM   #1
Rewards Points: 45
Bathroom Exhaust Fan Location in Drywall
Hi All,
I have drywalled a bit before, but now I am drywalling my own main bathroom ceiling solo, and require a tip.
What is the easiest to install, but best result for the location of my bathroom exhaust fan in the ceiling drywall. I have two options (Please see the attached jpeg for reference):
1) The fan located between a joint (so both sheets notched out). I feel it would be the easiest as I could install the fan and then place the drywall up and run my drywall saw along the two sides of the fan box.
2) The fan located near the edge of the middle drywall piece. This requires precise locational cut for the fan box. I also must be careful cutting close to the edge as it could break easily.
If anyone recommends 2) over 1), what is the minimum edge distance I can cut without issues?
Any help and suggestions are appreciated.
p.s. Prior to drywalling, should I tape the vapor barrier flaps into the fan box to seal?
Thanks!
trophywalleye is offline   Reply With Quote
Old 04-01-2011, 07:09 PM   #2
Originally Posted by trophywalleye View Post
Hi All,
Thanks!
Cutting the sheetrock is a simple matter using a sheetrock saw. Beam location is more important. It is easiest to locate the fan with one side next to a beam for solid fastening. I would sheetrock first, spackle and paint the ceiling. Prior to this I would decide on my location, measure it
out on paper, route the electric and put in the vent and hose and have everything set to go. Now cut out the size hole necessary , attach electric and hose, and secure fan to beam. Attach cover grate and you're done.
dadflynn is offline   Reply With Quote
Old 04-02-2011, 06:59 AM   #3
I'd gowith option 1. but like above, depends on where the joist are..
williamwiens is offline   Reply With Quote
Old 04-02-2011, 08:02 AM   #4
Rewards Points: 45
My ceiling joists run perpendicular to how I drew my drywall. My fan and ducting is already installed, however I am willing to modify it. One side of the fan is fastened to a ceiling joist via a bracket.
So if I drywall after the fact, I should go with option 1? I'm pretty set on drywalling after, unless its definitely not recommended.
williamwiens,
Have you seen option 1 done before?
More opinions appreciated.
Old 04-02-2011, 08:27 AM   #5
williamwiens,
Yes, option 1 will probably be easier for you to cut out the rock. Spackle thinly or your fan face isn't going to sit flat to the ceiling. Measure carefully and good luck.
Vent location for bathroom exhaust fan slapdash Remodeling 5 06-26-2012 10:38 AM
New bathroom drywall bowed in one spot, can I plane it? vacatari Drywall & Plaster 2 12-30-2010 08:40 PM
Suggestions for through-wall bathroom exhaust? frascati Electrical 1 11-04-2009 07:52 PM
Drywall for bathroom geoffthemonk Drywall & Plaster 4 11-01-2009 05:58 PM
New wiring and switch for bathroom exhaust fan looking4help75 Electrical 9 06-27-2008 04:15 PM
