Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 05-10-2012, 07:29 AM   #1
Bathroom Drywall Question
I am completely remodeling a bathroom and had a couple questions on the drywall. First question is where the drywall meets the tub/shower what is the best way to have a clean edge? I have to be honest and say I didn't quite get the drywall edge completely straight where it meets the tub. Also on the outside of the bathroom I had moved the door to a different location on the wall so I framed up the old doorway and decided to just put 3/8 drywall over the old plaster wall but the ceiling and the joining walls are still plaster. What is the best way to finish these edges (where the drywall meets the plaster walls and ceiling)?
bmwdr is offline   Reply With Quote
Old 05-10-2012, 09:43 AM   #2
Best way to have a clean edge is to cut it straight in the first place.
Are you using a drywall square to cut along?
Post a picture.
Old 05-10-2012, 10:08 AM   #3
Drywall and Painting Pro
Sir MixAlot's Avatar
After you cut the drywall fairly straight, you can clean up and straighten the edge out with a drywall rasp.
Checkout some of
Sir MixAlot is offline   Reply With Quote
Old 05-10-2012, 10:29 AM   #4
You could flat tape up to the ceiling, caulk, then prime and paint.
Checkout some of
Bathroom: Bare Green Drywall & Moisture drex Building & Construction 6 07-08-2012 09:02 AM
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 08:08 AM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 09:15 PM
Below Grade Bathroom Addition (Concrete / Flooring Question) cmremmert Building & Construction 1 07-12-2011 07:16 AM
Bathroom ventilation question - tight workspace! Hawkeye HVAC 2 08-18-2009 04:31 PM
