Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 05-04-2011, 09:18 PM   #1
Question
Bathroom drywall help
i would like to know if it would be ok to install mold&moisture resistant drywall?then just install that schluter kerdi over the drywall and install tile this is in a shower and one of the walls is a outside wall don't know if that helps or not
maxx is offline   Reply With Quote
Old 05-04-2011, 09:43 PM   #2
Stuck in the 70's
Blondesense's Avatar
My understanding is according the their website, Kerdi can be installed over drywall. Many people will use CBU anyway. Just sort of a belt-and-suspenders extra insurance type of thing.
If you are getting a permit and inspection, you might run it by your inspector first. If he's not familiar with the product he may question drywall in the shower.
FWIW, you might ask any additional questions about your shower in either the tiling (under flooring) or the bathroom/kitchen remodeling (under remodeling) forums. The tile guys who know about this stuff tend to hang around there.
The Following User Says Thank You to Blondesense For This Useful Post:
maxx (05-04-2011)
Old 05-05-2011, 07:37 AM   #3
Next Time...New Build
Jerdi can be installed over drywall with no issue. Cement board is probably your best option. I also believe that it is not necessary to use the green board if you are installing the kerdi, regular sheetrock would work fine. Check the schulter website, it explains what substrate can be used.
RickyBobby is offline   Reply With Quote
The Following User Says Thank You to RickyBobby For This Useful Post:
maxx (05-06-2011)
Bathroom: Bare Green Drywall & Moisture drex Building & Construction 6 07-08-2012 09:02 AM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 10:29 AM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 10:42 PM
Drywall bathroom ceiling docproteus Building & Construction 5 01-10-2008 08:05 AM
