Bathroom Drywall/Ceiling Intersection Popping Noise - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-28-2014, 07:35 PM   #1
Hey guys,
I bought this condo later last year; it was built in 1997. It was like early December or late November 2013 when suddenly I heard strange noise from master bathroom. It made us difficult to sleep and stay in our master bedroom.
The sound is from intersection of bathroom wall (beside bathtub) and ceiling. The noise is kind like popping sound. It's pretty loud and sharp. We can hear that even with bathroom and bedroom doors closed.
It seems that afternoon is when the noise is likely to come out, usually at 3-5 pm and continue for 20-60 minutes. The interval of a popping sound is like 10-20 seconds. When I push the bathroom drywall, I can hear sounds, I guess you can imagine the sound drywall makes, as well as the ceiling.
Also, there is a wood bolt inside the drywall (near intersection of ceiling). It's inside the wall and I can't take it out. What is that?
There are days that the intersection of ceiling and drywall don't make noise at all, but when they do make noise, it won't last more than 2 hours.
This is the Youtube for the noise. http://youtu.be/GJMgxLmyYTA
EricSea is offline   Reply With Quote
Old 01-28-2014, 07:52 PM   #2
Rewards Points: 5,974
Sounds like maybe someone is doing something in the unit above you and causing it.
Old 01-28-2014, 07:55 PM   #3
The noise started in November and lasts until today... I don't think caused by someone intentionally. The noise also happens at night/early morning when it's time to sleep.
Old 01-29-2014, 07:30 AM   #4
No didn't mean intentional they are just doing something different.
Old 01-29-2014, 07:42 PM   #5
Nahhh, it's from the wood frame or construction material I think. Is it possible to check the structure and pipes inside the ceiling?
Old 01-29-2014, 09:05 PM   #6
bbo
sure, tear into it.
bbo is offline   Reply With Quote
Old 01-29-2014, 09:26 PM   #7
If there is no access then you will need to cut a hole.
Old 01-30-2014, 08:17 AM   #8
Rewards Points: 1,426
What type of heating does the building have? Is this an interior or exterior wall? Do you know what is directly above the wall?
mikegp is offline   Reply With Quote
popping noise coming from walls Dan-diyer Building & Construction 6 11-30-2012 06:51 PM
Popping noise in pipe Mallard1123 Plumbing 5 10-18-2012 12:00 AM
How stop whining noise from bathroom faucet? Morris C. Plumbing 7 10-01-2012 08:44 PM
Pipe noise upstairs bathroom when running only warm water dial2fast Plumbing 1 12-04-2007 12:39 AM
Hear a Banging Noise from Bathroom Fan When its Windy wjk7320 Building & Construction 13 09-12-2007 11:13 PM
