Bathroom Ceiling Help - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-17-2012, 02:04 PM   #1
Bathroom ceiling help
My bathroom ceiling looks like it has been mudded in places several times and it's starting to crumble. Can I screw new drywall over the existing drywall ceiling or do I have to rip it all out? I dread ripping it all out because all of the insulation from the attic will drop into the bathroom. Any pointers would greatly help me! Thanks in advance!
fizzgig314 is offline   Reply With Quote
Old 05-17-2012, 02:25 PM   #2
hi tere, just make sure you locate center of joist for fixing new boarding. Also make sure you drop down the light and switch, but be careful. Make sure you use long enough screws to go through both pieces of plaster board and into the joist. Then re plastered.
tosh1 is offline   Reply With Quote
The Following User Says Thank You to tosh1 For This Useful Post:
oh'mike (05-17-2012)
Old 06-01-2012, 06:43 PM   #3
Drywall contractor
Rewards Points: 1,070
You have solved the issues as to WHY there was so much "mud work"?? You can add another layer. If there's been a moisture issue, and the drywall has sagged, there's another issue if it's blown-in insulation. Once the drywall sags the loose insulation get's between the joist and the drywall. you can't get the drywall to pull up to the framing. IF that's the case, tear it out....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Tags
bathroom , ceiling , drywall
Bathroom ceiling and walls HELP! Maia Painting 13 02-21-2013 03:21 AM
crack and stains in ceiling under bathroom diy_dude Building & Construction 0 08-06-2011 05:52 AM
HELP! Ceramic tiled ceiling in basement bathroom.... jrutherford Remodeling 1 10-11-2010 12:27 PM
Bathroom and textured ceiling painting? elementz Painting 6 10-01-2010 04:27 PM
finishing a bathroom ceiling mmhendrie Building & Construction 8 03-25-2009 03:01 PM
