Bathroom Caulking Help - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-10-2010, 01:48 AM   #1
I started another honey do list on the bathroom. I am trying to remove old caulk and did well on top of the shower but the gap looks like a 1/4 size crack between the drywall and the shower. Is there anything special I should do since the crack is larger than normal? Should I just keep filling it in until it is flush with the wall and shower? Also is there a way to remove off the daywall? Thanks for your help
bemgolf is offline   Reply With Quote
Old 02-10-2010, 06:33 AM   #2
Remodeling Contractor
in the gap install a backer rod (foam dowel material) then caulk with silicone caulk. Soften the old caulking with acetone then use a 5 in 1 tool to remove it. Use a sharp scraper on the drywall to remove it. then patch drywall if needed with compound.
Old 02-10-2010, 03:33 PM   #3
Thanks for the help
Old 02-10-2010, 04:01 PM   #4
Drywall contractor
Rewards Points: 1,070
Bob's advice is correct. The drywall should not come in direct contact with the shower unit as it will "wick" water/moisture and deteriorate over time (hence the 1/4" gap). Your drywall was installed correctly....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Caulking around bathroom sink KarenRB53 Plumbing 2 09-17-2009 11:21 AM
Bathroom Caulking help fishinggeek General DIY Discussions 1 08-28-2009 09:01 PM
Caulking Exterior Windows unixb0y Painting 1 06-04-2009 06:31 PM
bathroom caulking fabian Kitchen & Bath Remodeling 1 05-23-2009 09:27 AM
Bathroom Caulking satchmo Flooring 7 06-13-2007 06:43 PM
