Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 05-10-2012, 12:00 AM   #1
Bathroom - 1/2" Purple Board
I sheetrocked my master bathroom myself and used purple board for the walls and ceiling except for above the shower. I used Durarock above the shower which will get tile. I'm in the process of getting prices from drywallers and all of them are saying that you can't use purple board on the ceiling, but none of them can't tell me where in the code it says that. Does anybody know if they are correct or not? This is in N. Calif.
Woodbutcher123 is offline   Reply With Quote
Old 05-10-2012, 08:21 AM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
It is meant for wet spaces, so it does not matter in my opinion. In their opinion, it may be that they are not used to dealing with the Purple board, which is no different than the Green board. Just a different color. I would make a quick call to your AHJ, and while you are talking, just happen to drop the companies names into the conversation, so they know they are the ones telling you this info.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 05-10-2012, 08:44 AM   #3
It's just mold and moisture resistant drywall and should not be a problum.
Only thing I can think of is in some areas local code is calling for paperless drywall in bathrooms.
There should be a brand name on the backside of the boards look up there website and see what they say about it's useage.
Old 05-10-2012, 10:01 AM   #4
Drywall and Painting Pro
Sir MixAlot's Avatar
From National gypsums website:
http://www.nationalgypsum.com/produc...ProductID=2413
Basic Uses
XP Gypsum Board may be installed in all wall and ceiling applications and is ideally suited where enhanced moisture and mold resistance is desired.
Gold Bond XP Gypsum Board
Checkout some of
Sir MixAlot is offline   Reply With Quote
Old 05-10-2012, 08:18 PM   #5
i used purple in a shower ceiling this past weekend. i don't see why that wouldn't be good.
*edit*
is their issue the 1/2 thickness on the ceiling instead of 5/8?
sevenlol is offline   Reply With Quote
Old 05-10-2012, 09:59 PM   #6
gregzoll's Avatar
That is my guess sevenlol.
Old 05-11-2012, 12:51 AM   #7
Moderator
Perhaps they are getting it confused (or don't know) with the older "greenboard" which this board replaced. Per code, the greenboard needed 12"o.c. ceiling framing, the purple board requires 24"o.c. for 1/2": http://publicecodes.citation.com/ico...002_par013.htm
http://www.nationalgypsum.com/produc...e%5C111081.pdf
Gary
Clothes taking longer to dry?
Bathroom Remo: Is this Plaster over Concrete Block? Mounting Backerboard over top? itcanadian Remodeling 10 03-21-2011 01:06 PM
Purple board?? Lafayette Drywall & Plaster 7 03-18-2011 08:07 AM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 10:47 PM
Bathroom fan replacement reveals...a mess merlanvp Electrical 0 07-25-2010 09:00 PM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 10:29 AM
