Basic Taping/missing Question - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-26-2013, 07:59 AM   #1
Rewards Points: 85
basic taping/missing question
Hi there. Will be drywalling for the first time soon. Have been watching many videos on taping/mudding, and there is something I haven't seen explained.
When you have a vertical seem meet a horizontal seem, how do you do tape? Do you just overlap the tape in each spot or do you have to tear the tape at the right length so they don't overlap?
Or is it not a big deal either way?
Thanks!
joshs is offline   Reply With Quote
Old 03-26-2013, 08:04 AM   #2
Rewards Points: 14,010
Butt them do not over lap.
Two layers will be harder to feather out.
Old 03-26-2013, 08:10 AM   #3
Rewards Points: 85
How perfect do I need to be when I butt them?
Old 03-26-2013, 08:37 AM   #4
Rewards Points: 150
You're talking about the two layers of paper tape overlapping? Yeah that doesn't matter at all. Like where a horizontal seam meets a vertical corner... I would do the horizontal first because that's a tapered edge. Run the paper clear to the corner. Then do your corner. Don't even have to wait for it to dry, just mud and run your corner tape right over the horizontal tape.
SquishyBall is offline   Reply With Quote
Old 03-26-2013, 08:42 AM   #5
Rewards Points: 85
I was thinking in the middle of the room too. With staggered sheets there will be one long horizontal seem and then a vertical seem every 4 feet.
I was wondering if overlapping would mean having to build up the spot more and lead to feathering further out. If I don't overlap and just butt the ends of the tape together is a small space ok or do I really need to be perfect with the 2 ends?
Old 03-26-2013, 09:12 AM   #6
Rewards Points: 150
There, I would do the taper first. Then run the vertical up to it and overlap. I don't measure and cut my tape, I just mud the joint, unroll till it seems "about right" and tear it off. They'll overlap in a tapered zone so it'll come out flat when done. I suppose where that vertical joint meets the ceiling, you'll have two pcs of paper overlapping but it won't be any more obvious than the rest of your butt joint. In ceiling corners (wall-wall-ceiling) you can get some overlap too. Totally non-impacting that extra paper width in there.
Old 03-26-2013, 09:28 AM   #7
Rewards Points: 85
Thanks for the reply. I'm sure I'll come up with many questions as I start the project :-)
Old 03-27-2013, 05:48 PM   #8
retired union carpenter
Send a message via Yahoo to coupe
whenever I went into a house to begin finishing, I'd start in one room, bed all butt joints first run tape all way into inside corners and to within 1/2" of horizontal joint top and bottom. once butts are done in entire house, I'd go back to first room and run horizontal joints tape to 1/2" of corners. then go again to first room and start running my inside corners ceilings first. that way everything is overlapped, only raw tape ends are at bottom at floor.
any other way than with a concave knife or trowel, that raw end of tape can be brought to each coat. even if only slight ridge it's an unneeded ridge and leaves the end susceptible to coming loose or getting caught on something at some time, maybe during sanding?
as always,"just my thoughts" others may disagree?
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 03-27-2013, 06:20 PM   #9
Drywall Finisher/Hanger for a living.
**Make sure your furnace vents are closed off. You will destroy your pipes during this process if not**
Simple steps except for hand finishing...
1) Check all screws in angle make sure none are protruding.
2) Mount your bead on corners/door wraps
3) Prefill all butt joints/bastard joints(where a flat would meet a butt joint)
4) Tape all your butt joints. Crossing over the flat seam is fine as long as it doesn't extend past the outside of the flat tape edge. So about 1" over or before flat joint is fine.
5) Tape your flats
6) Tape your angles. Make sure if you plan to machine coat the angles, not to hand tap the angles in. Angle coat for 2nd time won't go very smoothly.
7) Let all that dry for atleast 18-24hrs
8) Coat your bead 8" out
9) Coat your flats 10" Wide
10) Coat your butts 10" wide on left and right side of butt
11) Let that dry 18-24hrs
12) Coat your angles
13) Coat your bead 10" out
14) Coat your flats 12" wide
15) Coat your butts 12" wide once down center
16) Let that dry 12-18hrs
17) Touch angels up
18) 3rd Coat bead 10" wide (Skim coat)
19) 3rd Coat Butts (Skim Coat)
20) Let that dry 6-12hrs
21) Final Sand!!!
*USE A 500w Halogen Light to shine down the walls on Touch Up + Sand* You will save yourself tons of hours of touchup. W/o u will never see half the flaws until you primer+pant+sun hits the right angel.
DukeLewis87 is offline   Reply With Quote
The Following User Says Thank You to DukeLewis87 For This Useful Post:
Deja-vue (03-28-2013)
Old 03-28-2013, 10:39 AM   #10
Rewards Points: 5,982
The only thing Duke is being DIY almost everything is hand troweled not to many have mud boxes. I usually do my long horiz. seams first and I tear or cut my tape so it is about 1/2" short of meeting the other wall. This is because when you are setting your tape(pulling the mud from under it) if you run the tape all the way to the corner it makes it hard for the tape to get out from under, so you end up with a blob right in the corner. As far as butt joints I use butt boards and completely eliminate them. Makes things a lot easier for someone new. and yes it doesn't hurt if your tape is overlapped some it's going to be in the corners too. This is all based on using paper tape not mesh.
ToolSeeker is online now   Reply With Quote
Old 03-28-2013, 10:46 AM   #11
Rewards Points: 85
Thanks again for the replies.
Still have a question about butt boards. Do they provide enough support for drywall since they are not fastened to studs? I'm not going to lean on the wall and have it collapse right?
Old 03-28-2013, 11:08 AM   #12
No more than if you leaned on the drywall. I have used them for customers , for my daughter, for my grand daughter, and in my own home and have never gotten a call back for one.
basic gas heating question diy'er on LI HVAC 10 11-09-2012 04:14 AM
basic code question deko Electrical 3 01-13-2011 01:26 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Basic wood cutting question sharding Carpentry 4 08-02-2008 04:56 PM
Some basic question about roofing help! motd0iyeuem Roofing/Siding 6 12-19-2005 07:15 AM
