Basement Remodel Using Green Home Theory? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-10-2012, 11:42 AM   #1
Basement remodel using green home theory?
Would like to remove the paneling from my basement walls and replace with a type of drywall that would be environmentally safe and moisture resistant. Any thoughts?
lowheat is offline   Reply With Quote
Old 01-14-2012, 01:20 PM   #2
Send a message via Skype™ to LHazleton
Just use MR sheetrock. Due to its blue or green color, you'll want to us a good quality primer to prevent bleeding.
LHazleton is offline   Reply With Quote
Old 01-14-2012, 02:59 PM   #3
MarginallyQualified
Rewards Points: 2,464
and replace with MR drywall... Any thoughts?
About 200 moisture, insulation and ventilation questions come to mind.
Poke around in some of the other insulation and remodeling threads.
Old 01-14-2012, 06:26 PM   #4
Registered User
Rewards Points: 5,514
Sounds like the 8o's with paneling.... Might want to research this a little: http://www.buildingscience.com/docum...lation-systems
No green board in basements, you want the moisture to dry to the inside. It has a moisture-resistant core and paper. Helps vapor condense in the stud cavity.
And welcome to the forums, both of you!
Gary
Insulating unfinished basement, First time home owner please help! ashory Building & Construction 7 08-25-2011 11:44 PM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 05:18 PM
smell in finished basement of newly purchased home triathloncathy Flooring 11 07-17-2010 09:04 PM
Older basement shower needs remodel. Questions about showers and concrete blocks. speedster1 Remodeling 6 01-28-2010 02:55 PM
Control Dust in Basement Remodel Siamese Remodeling 4 03-19-2008 02:47 PM
