Basement Partition Walls - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-14-2016, 03:12 PM   #1
Rewards Points: 8
basement partition walls
I am re-finishing the basement a previous HO started, and am removing the wood paneling and installing moisture resistant drywall instead. I have some partition walls separating the living space from the basement space and was wondering if I should use moisture resistant drywall on that too or if i am ok just using normal rock? Basement is mostly water-tight but there is a little moisture here and there (working on remediating that too). I just don't want to regret anything down the road, but don't want to spend money unnecessarily if I can avoid it (which is why I'm doing the work myself).
Also, would you insulate the wall too? Foam board cut into the spaces or bats?
Thanks.
aadepa is offline   Reply With Quote
Old 03-14-2016, 05:42 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,608
Re: basement partition walls
Why are you putting moisture resistant drywall in?
If there is moisture in the walls and getting in via the conditioned air or from the basement wall, the drywall choice isn't the solution.
I would suggest you browse around the insulation sub section and start reading up on basement insulation strategies.
How is the wall insulated now and where is the home?
http://buildingscience.com/documents...ts?full_view=1
Old 03-14-2016, 09:52 PM   #3
Rewards Points: 8
it's a 100 year old house in Missouri. Using moisture/mold resistant drywall as a precaution. None of the paneling i removed had any indication of mold, but an ounce of prevention is worth a pound of cure. As installed by the previous HO, they put R11 fiberglass insulation on the exterior walls. I've removed that and am in the process of installing foam board instead.
Old 03-23-2016, 12:31 PM   #4
Rewards Points: 8
So going back to it, is there any suggestion on whether a partition wall should have moisture/mold resistant rock or just regular? thanks
Old 03-23-2016, 12:56 PM   #5
Rewards Points: 144
Just use regular drywall and hold it 1/2" off the slab.
mako1 is offline   Reply With Quote
Old 03-24-2016, 08:52 AM   #6
Rewards Points: 242
I'd use the mold resistant stuff. I just gutted my basement. It was remodeled about 10 years ago. The prior owner built interior and exterior walls. I found mold behind almost all of the drywall. It was not good. Granted, there was no vapor barrier or insulation anywhere, so I can't just blame the drywall.
I'm redoing it properly, and I'm using the mold resistant drywall everywhere as a precaution. No matter how well you insulate, you're going to get some moisture in a basement. Why take a chance for a few $ more per sheet.
b-boy is offline   Reply With Quote
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
What to do with basement walls. RR. Remodeling 3 02-20-2012 06:49 PM
Insulate rim joist & basement walls- if exterior walls have no insulation? cbrc5eric Insulation 5 02-01-2012 07:47 AM
Insulating interior basement walls brazzle Insulation 3 05-04-2011 07:24 PM
Basement Walls - Which Paint?Drylok? HandyFrank Building & Construction 3 10-17-2010 12:07 PM
