Basement Drywall Questions - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-11-2016, 05:38 PM   #1
Rewards Points: 254
Basement drywall questions
A few questions about drywall for my basement finishing project:
1) Is it cheaper installing drywall myself and hiring out the taping plaster? Or is it true that drywall contractors get drywall much cheaper than I could at the Home Depot?
2) Is mold resistant drywall a good idea for below-grade installations? Even for the ceiling?
3) All the audio guys seem to think that 5/8 drywall is needed for sound deadening. I'd like to keep as much noise down in the "man cave" as possible.
Do I need 5/8 for walls and ceiling? Or just 5/8 for ceiling?
gizzygone is offline   Reply With Quote
Old 03-11-2016, 07:38 PM   #2
Rewards Points: 12,868
There not going to get it much cheaper just be able to install it far faster and have it come out right.
If you have added 2 foam on the foundation, framed the walls out away from the foam,
Used R-13 insulation and added a vapor barrier over the studs then there's no need to any special drywall.
5/8 on the walls is not going to do a thing to stop sound.
Truly want sound want sound proofing just using thicker sheet rock not going to do much.
http://www.soundproofingcompany.com/...oof-a-ceiling/
Old 03-11-2016, 07:41 PM   #3
Rewards Points: 254
Were going with just spray foam directly to the concrete.
Old 03-12-2016, 08:50 AM   #4
Rewards Points: 5,974
Re: Basement drywall questions
Most dry wallers prefer to hang their own. They can eliminate taping problems as they go. As for price there is not much difference in a few sheets, if doing a whole house and they purchase a couple hundred sheets then they get a break.
I have went to a couple jobs where the HO hung the rock and it was so bad we had to remove it and start over. And some where the HO did a really good job. Not knowing your skill level makes your question a little hard to answer.
Entering your general location can help with answering a lot of times
Old 03-12-2016, 10:32 PM   #5
Rewards Points: 6
I did 2" foam board on my foundation walls and then rolled R-13 insulation between all studs that I did myself. I then hired a pro to do the walls and ceiling , tape, mud and supplies. The price was definitely right and it'll come out far better and in a much faster time frame than I could achieve.
Sent from my iPhone
Aaron1085 is offline   Reply With Quote
Old 03-12-2016, 10:33 PM   #6
Rewards Points: 6
Not done yet, drywall, tape and mud went up yesterday. Sanding tomorrow.
Sent from my iPhone
Old 03-13-2016, 07:45 AM   #7
Rewards Points: 254
Sent from my iPhone
Would you mine me asking what kind of drywall you went with? How large is your basement, and how much was the project? I started getting a few quotes and they range from $4000 to $8000
Old 03-14-2016, 12:06 AM   #8
Electrician
Rewards Points: 760
What would a home owner do to make the drywall so bad you had to rip it out, I may learn a thing or two about how not to hang drywall.
darren is offline   Reply With Quote
Old 03-14-2016, 09:16 AM   #9
The biggest problem was trying to save pieces. This created many butt joints. Leaving too big a gap, and the cut outs for plugs and switches were cut wrong then the hole was too big or in the wrong place. Seams in the wrong place like the corner of a door or window where it is very likely to crack.
The Following User Says Thank You to ToolSeeker For This Useful Post:
Gymschu (03-14-2016)
Old 03-14-2016, 04:00 PM   #10
Gymschu's Avatar
Rewards Points: 236
Toolseeker, I've also seen drywall hung and NOT NAILED TO ANY STUDS AT THE END OF THE PIECE. If the 8 footer ended up a foot shy of the next stud, they just left it like that and installed the next piece right next to it!!! One lean on the wall...........
Giving us your general location helps us better help you!
The Following User Says Thank You to Gymschu For This Useful Post:
ToolSeeker (03-15-2016)
Old 03-14-2016, 08:16 PM   #11
Rewards Points: 254
I'm starting to reconsider doing this myself: if the only problem is the idiot installers, then I think I can handle the job myself.
I think my biggest concern would be making sure I get the joints all correct.
Old 03-15-2016, 08:33 AM   #12
Myron Ferguson has a really good book on drywalling if your unsure. There are some good videos on You Tube the problem being there is also some really bad ones.
Old 03-15-2016, 09:00 AM   #13
Rewards Points: 254
I'll have to look the book up. Does it have lots of pictures? (Hey, don't judge!)
I've been watching you tube videos, but certainly having a hard time with picking out the pros, vs the wannabes. I'm really having a hard time figuring out the hanging of drywall over outlets: some say to hang the corners and use a rotozip (which looks a lot cleaner) and others use some crazy tricks, like lipsticking the box then cutting then hanging...
Old 03-15-2016, 12:44 PM   #14
Rewards Points: 1,010
I'd go with 5/8" for better soundproofing as well as a better fire rating. And don't install a vapor barrier behind it - that will trap moisture and lead to mold and mildew problems.
Also there's a great thread on here about fire block framing -
How to fireblock framing
It's basically a way to help suppress any fires that may ignite behind the drywall and hopefully prevent it from spreading upstairs.
spaceman spif is offline   Reply With Quote
Old 03-15-2016, 02:52 PM   #15
Rewards Points: 254
Now I heard 5/8 makes for much more difficult door installations? Plus it's not stocked by the local big box stores (at least mold resistant versions)
Questions about framing in stairs to basement motoriderx7x Building & Construction 2 02-02-2016 08:49 AM
Basement reno questions creamaster Building & Construction 9 12-22-2015 04:23 PM
Questions about holes in drywall, uneven ceilings, and refinishing after popcorn Joe Link Drywall & Plaster 1 08-21-2014 08:27 AM
Drywall on Concrete Basement Walls? jedingledy Building & Construction 7 08-12-2014 05:38 AM
Drywalling a basement... should I leave a gap at bottom of drywall? roasted Drywall & Plaster 7 06-22-2013 09:41 AM
