Basement Celing - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-24-2009, 02:15 PM   #1
Basement celing
I'm going to be drywalling a basement and doing the ceiling for it. I'm wondering if I should run some 2x4's perpendicular to the joists and attach the dry wall to that - rather than hanging the drywall directly to the floor joists.
cornick is offline   Reply With Quote
Old 12-24-2009, 03:10 PM   #2
Remodeling Contractor
Why? For sound deadening you could use resilent channel for this same design. At least you would gain something. Or you run these to drop the ceiling due to pipes or electric wires requiring concealment. Or to make up for an unveven surface. Or to provide a 16" OC nailer if your joists are 24"OC. Otherwise there is not reason to do this.
Old 12-27-2009, 07:38 PM   #3
Agreed , do not strip unless you have to for either sound or to take the high and low areas out. Otherwise just screw to the floor joists.
silverstilts is offline   Reply With Quote
Old 12-28-2009, 05:14 PM   #4
Drywall contractor
Rewards Points: 1,070
Yeah, if you've got floor joists or trusses over 16" centers, strap with 1"x4" on 16" centers.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 12-29-2009, 01:17 PM   #5
Cant 5/8 drywall be used for 24"OC?
bkeech is offline   Reply With Quote
Old 12-29-2009, 02:46 PM   #6
Drywall contractor
Sure if you want to deal with the additional weight.....
Old 12-29-2009, 03:45 PM   #7
Not on a ceiling. Sags too much. I would not even use it for walls. Why make a poor wall when a very little costs makes it so much better.
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 05:44 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 11:52 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
