Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 01-29-2011, 10:23 AM   #1
MikeKy55's Avatar
Basement ceiling duct metal
When you put up drywall on the floor joist above a basement and cross over a sheet metal air return duct built in the cavity, do you predrill for the drywall screws? Or will they run on thru the metal?
MikeKy55 is offline   Reply With Quote
Old 01-30-2011, 10:35 AM   #2
Drywall contractor
The screws will run in without pre-drilling. Depending on the gauge of the metal, you may need self tapping screws however. They have a small drill point on the end (available at HD & Lowes). How much of a span are you trying to go over?? You may not need to attach to the duct work. If you're spanning 16" or less with 1/2" or 24" with 5/8", no need to screw to the duct.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 01-30-2011, 06:12 PM   #3
MikeKy55's Avatar
The areas I was concerned about were where the air returns and built using the joist cavities. There are two side by side so I'm spanning 32 inches. But if the drywall screws will go thru, I'm good. This house is about 8 years old, so the metal is thin. My last house was built in 1959 and the metal in those ducts had to have been 20GA.
Old 01-30-2011, 07:20 PM   #4
You should be able to screw with regular 1 1/4" drywall screws. I have done it many times before, but I was using a drywall screw gun, you don't want to over spin if you don't have a drywall screw gun, or it might not hold. If you have problems, they also make metal drywall screws for channel that might worker easier.
redmanblackdog is offline   Reply With Quote
The Following User Says Thank You to redmanblackdog For This Useful Post:
MikeKy55 (01-30-2011)
Basement ceiling question aggst1 Remodeling 9 05-07-2013 04:23 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 05:44 PM
insulating duct work in basement Master Brian HVAC 10 05-19-2009 11:28 AM
basement ceiling joists-how to know if they are level? yummy mummy Building & Construction 22 02-06-2007 09:16 AM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 09:27 AM
