#1 |
Basement Ceiling Drywall Thickness
Hey everyone, first time poster here. In the past I have heard that I am supposed to use 5/8 inch sheetrock for the ceiling in the basement that I am finishing due to code. Is this correct or can I get by with 1/2 inch?
#2 | |
many places will allow using 1/2 inch, but 5/8 would be better for sound-proofing and fire protection.
price them and see if 5/8 is too much for the budget. *edit* How to fireblock framing
#3 |
Super Moderator
Check your local code--Many towns and counties have the building codes on the internet--
Call or google the info.--Always best to follow the local code.--MIKE-- |
#4 |
Very good advice above...always check for code requirements and if permits are required.
5/8" rock is good practice if joists are on 24" centers (avoid sag). / common floor for 1st story and basement ceiling is assume might be on 16" CENTERS. This should work fine for 1/2" rock. Insulating might be a plus if you have zoned air and like it warm and cozy on the main floor. (insul $) Yep, a long pay back ,but warm and cozy is right away. Have fun |
#5 |
Drywall contractor
And the insul. will help deaden noise somewhat, whether it's the "clack" of footsteps on the hardwood/tile upstairs or the noise of the kids playing downstairs. Worth the investment in my opinion....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops. |
#6 |
last i checked....there is NO code requirement to even put a finished ceiling in the basement(check your local). the only requirement i have ever seen is if you have a garage in the basement of the house. in that case the entire garage, walls and ceiling must be of 5/8" fire code (sometimes called type "X") drywall. this produces the required 1 hour assembly required by code. the door to the house will have to be a 1 hour labled door as well. another technical thing is.... to be code compliant, it (the drywall) must be "fire code" drywall and it must be printed,by manufacturer, on the drywall to comply. regular 5/8" drywall is NOT code compliant and will probably have to be ripped out and preplaced with the proper stuff if the building inspector wants.
whatever you get, rent one of those drywall lifts....trust me it'll be the best investment to your sanity that you can make when it comes to hanging drywall on a ceiling! good luck |
#7 |
something else to consider is the joist spacing. 24" needs 5/8 drywall to avoid saging.
#8 |
Drywall contractor
As Big Bob stated above.
#9 |
Thanks guys for the advice. I checked with my wifes relatives that just had their basement finished in the same town and they said 5/8 inch needs to be used for fire code.
#10 |
PHB Construction LLC
Do yourself a favor and rent a lift for the 5/8's. It makes all the difference in the world and I would NEVER do a 5/8's ceiling without one.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#11 |
Yes or buy one off of ebay. Thats what I did. Those 12' 5/8 are heavy.
| Display Modes | |
| Drywall ceiling: Water Damage, looking for advice | dawho1 | Building & Construction | 11 | 09-13-2010 11:05 AM |
| ? Framing flat drywall ceiling in basement bath. | misshaley | Building & Construction | 0 | 01-17-2010 01:09 PM |
| Hanging drywall basement ceiling from engineered wood I-beam joists | ja_trusty | Building & Construction | 6 | 10-09-2008 12:06 PM |
| Drywall thickness on ceiling question. | Doug Crf | Building & Construction | 3 | 08-28-2006 06:47 AM |
