Basement Ceiling Drywall Question - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-05-2012, 11:56 PM   #1
Rewards Points: 89
Have 24 inch O.C. Floor joists,will I need to place 5/8,or is there a 1/2 inch product that I can install.
Looking to do some sort of texture on the ceiling.
Worried about it sagging,as it is a 40 foot run of board.
spring3100 is offline   Reply With Quote
Old 11-06-2012, 12:00 AM   #2
Rewards Points: 13,300
Why not be safe and just use 5/8?
With a drywall lift and using 12' long sheets it's no harder then using 1/2"
spring3100 (11-06-2012)
Old 11-06-2012, 05:37 PM   #3
Rewards Points: 512
there is 1/2 sag resistant and i believe the new ultra light drywall is rated for 24" centers. save your back and get the 1/2. 5/8" is always so much more of a pain.
princelake is offline   Reply With Quote
The Following User Says Thank You to princelake For This Useful Post:
mae-ling (11-06-2012)
Old 11-06-2012, 06:11 PM   #4
Rewards Points: 2,210
5/8" can also be fire rated which may be a concern. If not the 1/2" light/ceiling board/whatever they call it is great to work with.
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
princelake (11-06-2012)
Old 11-06-2012, 09:30 PM   #5
Rewards Points: 512
yup i only use 5/8" if it has to be meet fire code or to match up old drywall.
Old 11-07-2012, 08:37 PM   #6
Rewards Points: 5,974
Since a basement ceiling is usually filled with all sorts of goodies like pipes, wiring, and other things have you considered a drop ceiling so you will have access?
Old 11-08-2012, 06:29 AM   #7
Rewards Points: 89
It is a truss floor,so all piping and wiring is already hidden,trying to make the basement look exactly like the rest of the house,as it is a walkout with a waterview,it deserves it! Thanks for the input
The Following User Says Thank You to spring3100 For This Useful Post:
ToolSeeker (11-10-2012)
Old 11-08-2012, 06:29 PM   #8
Rewards Points: 512
ya i kind of agree with toolseeker. even if they are hidden, pipes can burst, electrical can screw up. there are lots of options for nice looking tiles to give you access to everything. but i have to say drywalled basement ceilings do look good. atleast put in some access panels or heat registers.
Old 12-05-2012, 06:05 PM   #9
Drywall contractor
Rewards Points: 1,070
Price the drop ceiling compared to drywall...metal is very expensive. I do both types of ceilings and I would recommend drywall unless there's just too much "stuff" to frame around. Go to the USG website and you'll find the new lightweight 1'2" drywall is acceptable for 24" centers with a "water based texture" applied. WHY FIGHT 5/8" IF YOU DON'T HAVE TO? You've got "hidden pipes and electrical that can screw up" on the main floor(s) of the house, but you don't put in drop ceilings! Frame around any water/gas shutoffs and use a return air grill to hide it. (Or there are plastic access panels available at HD or Lowes.) Use adhesive and screws/nails.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
The Following User Says Thank You to bjbatlanta For This Useful Post:
princelake (12-05-2012)
Ceiling Drywall question Mstrenke Drywall & Plaster 9 05-19-2012 12:09 AM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 09:15 PM
Basement Ceiling DIY_ing_Guy Building & Construction 2 10-17-2011 07:54 PM
finishing basement - ceiling question mikeluvs2build Building & Construction 0 03-16-2010 11:43 PM
ceiling drywall question DangerMouse Drywall & Plaster 5 10-17-2008 02:32 PM
