Baseboard Dilemna - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-31-2012, 08:46 AM   #1
Baseboard Dilemna
I removed old plaster and lath and installed drywall, but now there is a 2 1/2" gap between the drywall and the finished hardwood floor. How do I deal with this? Looked into stacking baseboard, but just gets too busy looking. Help!
Steve Ca is offline   Reply With Quote
Old 07-31-2012, 08:56 AM   #2
Rewards Points: 13,300
Post a picture.
Is the dry wall finished yet?
The wall should have been shimed out before installing the drywall.
Steve Ca (07-31-2012)
Old 07-31-2012, 12:11 PM   #3
Rewards Points: 2,210
Another option is to go with baseboard taller then the gap, so it covers. Put strips of plywood in the gap the thickness of the gap as a filler.
mae-ling is offline   Reply With Quote
Old 07-31-2012, 05:36 PM   #4
Picture and one possible resolution
Here is a picture that shows the gap and one possible resolution. Any ideas?
Old 07-31-2012, 05:42 PM   #5
Attempt 2
Second attempt to post pic. Drywall is already finished
Old 07-31-2012, 06:10 PM   #6
Looks like poop.
Your trying to use 1/2" thick base board.
Use 1 X 6 pine instead, that alone will gain you 1/4", then you use base cap moulding on the tops of the base. Adding 3/4 X 3/4, 1/4 round will make the base your trying to use under the baseboard stick out less.
Old 07-31-2012, 06:19 PM   #7
Poop
Agreed. Just used scraps for image. The base under the baseboard is the issue, it has to be 2 1/2" at widest point.
Old 08-01-2012, 06:39 PM   #8
paper hanger and painter
chrisn's Avatar
Rewards Points: 236
Originally Posted by joecaption View Post
Looks like poop.
poop!
chrisn is online now   Reply With Quote
Old 08-10-2012, 08:29 PM   #9
Maybe add some kind of a decorative border to your floor. Easier than starting your drywall job over.
chrisBC is offline   Reply With Quote
Old 08-12-2012, 08:34 PM   #10
I'd try a small dowell rod to fill in the gap. If the gap is consistent just get the right size so you can tap it in.
TSGR is offline   Reply With Quote
hot water baseboard flow question (long) fred54 HVAC 4 10-14-2011 04:39 AM
Problem with 240V Elect Baseboard Heater JRHP Electrical 4 10-04-2010 10:30 AM
Laminate flooring / baseboard gap question willy0314 Flooring 0 08-07-2010 10:48 PM
Partial hydronic baseboard to radient floor conversion Jeepsail HVAC 4 01-17-2010 05:47 PM
Baseboard dilema Allyson Flooring 5 09-04-2009 09:30 AM
