-   -   Baseboard Dilemna (http://www.diychatroom.com/f101/baseboard-dilemna-152094/)
Steve Ca 07-31-2012 08:46 AM
Baseboard Dilemna
I removed old plaster and lath and installed drywall, but now there is a 2 1/2" gap between the drywall and the finished hardwood floor. How do I deal with this? Looked into stacking baseboard, but just gets too busy looking. Help!
joecaption 07-31-2012 08:56 AM
Post a picture.
Is the dry wall finished yet?
The wall should have been shimed out before installing the drywall.
mae-ling 07-31-2012 12:11 PM
Another option is to go with baseboard taller then the gap, so it covers. Put strips of plywood in the gap the thickness of the gap as a filler.
Steve Ca 07-31-2012 05:36 PM
Picture and one possible resolution
Here is a picture that shows the gap and one possible resolution. Any ideas?
Steve Ca 07-31-2012 05:42 PM
Attempt 2
1 Attachment(s)
Second attempt to post pic. Drywall is already finished
joecaption 07-31-2012 06:10 PM
Looks like poop.
Your trying to use 1/2" thick base board.
Use 1 X 6 pine instead, that alone will gain you 1/4", then you use base cap moulding on the tops of the base. Adding 3/4 X 3/4, 1/4 round will make the base your trying to use under the baseboard stick out less.
Steve Ca 07-31-2012 06:19 PM
Poop
Agreed. Just used scraps for image. The base under the baseboard is the issue, it has to be 2 1/2" at widest point.
chrisn 08-01-2012 06:39 PM
Originally Posted by joecaption (Post 978560)
Looks like poop.
poop!:laughing::laughing:
chrisBC 08-10-2012 08:29 PM
Maybe add some kind of a decorative border to your floor. Easier than starting your drywall job over.
TSGR 08-12-2012 08:34 PM
I'd try a small dowell rod to fill in the gap. If the gap is consistent just get the right size so you can tap it in.
