Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 04-21-2009, 09:22 AM   #1
They're all fixer-uppers
J187's Avatar
Is it bad practice to drywall like this?
I am remodeling a bathroom. Getting ready to drywall the wall in back of th vanity. The existing supply lines coming out of the wall have shutoff valves. In order for me to fit the drywall tightly around the pipe and use an escutcheon to the wall, I would have to remove the shutoff valves.. not a huge deal, but this whole area will be hidden by the vanity and I could actually just cut a long rectangle in the drywall and slip it over everything. Is this bad practice??
J187 is offline   Reply With Quote
Old 04-21-2009, 09:35 AM   #2
the Musigician
DangerMouse's Avatar
i've seen it done...... however, it'll allow easier access to rodent/bugs/drafts
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 04-21-2009, 10:48 AM   #3
RippySkippy's Avatar
I would do as you say cut the large rectangle. Then put a filler patch in after it's installed, using dura-bond to tape and fill in round the pipe, no one will be the wiser. While you could leave it open...I'd prefer not to....but that's just me.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 04-21-2009, 10:59 AM   #4
Newbie Bill
Couldn't you just use two pieces of drywall? One that comes up to the pipes from the bottom and one coming down to the pipes from the top. Then you would only have one joint.
drtbk4ever is offline   Reply With Quote
Old 04-21-2009, 02:19 PM   #5
J187's Avatar
Maybe if I was hiring out the finishing...
Seriously though, I'd rather deal with the pipes than make an extra seam to tape. Thanks for the suggestion though.
Old 04-21-2009, 03:13 PM   #6
the Musigician
i'm with you 100% there brother, heh heh... some of us will do ANYthing to get out of tape and mud......
My $40 (300 sq. ft.) Homemade Birch/Walnut Ceiling
see? lol
DM
Old 04-21-2009, 03:45 PM   #7
Drywall contractor
Cut the hole big enough to go over the supply and patch around it would be the easiest. If it's under the cabinet, it's up to you if you want to do it or not...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-21-2009, 03:47 PM   #8
J187's Avatar
Thats what I'll do. Thanks.
Old 04-21-2009, 04:34 PM   #9
Newbie Bill
I figured the joint would be behind the vanity so finishing wouldn't be an issue.
Old 04-21-2009, 09:43 PM   #10
Remove the handle first and make 1 smaller hole. If cut right the escutcheon will cover it.
Mop in Hand is offline   Reply With Quote
Old 04-22-2009, 06:16 AM   #11
How big are your shutoffs. Can't you make 2 clean holes with a hole saw.
Chemist1961 is offline   Reply With Quote
Old 04-22-2009, 06:30 AM   #12
SDC
SDC's Avatar
Why not shut the water down, remove the shut offs, put caps on the plumbing, install the drywall, install the cabinet, install the shut offs? This way you end up with no seams or joints in the drywall, and holes just the size of the pipes
SDC is offline   Reply With Quote
Old 04-22-2009, 08:54 AM   #13
Just guessing by the original and subsequent post, it seems as though he's looking for the easiest way out. You're right...it's not a big deal to do as you say...and it would look the best.
LMASD
Old 04-23-2009, 02:12 PM   #14
J187's Avatar
Not really. As I said originally, if removing them is the right thing to do, no big deal. I just wanted to make sure I wasn't going to the trouble for no reason is all. I was curious about general practice, as if someone may have said "no, typically people just cut around them as everything is hidden"... or "you can do it any which you that works, but the best thing to do is take all the shutoffs off, cap the plumbing and go that route".
Old 04-24-2009, 11:47 AM   #15
You should remove the valves If you don't you will have to drill two large holes in the cabinet to get valves in the cabinet. That will look like do do
eidol is offline   Reply With Quote
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 01:05 PM
Old ceiling replacement idsp General Discussion 12 07-25-2009 11:48 AM
Drywall over plaster? Rob1980 Drywall & Plaster 10 04-11-2009 06:05 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
